Old 07-25-2007, 01:56 PM   #1 (permalink)
Car: 1995 Integra GS-R
Mods: JRSC, Jackson Racing Pully (upgrade boost),DC Header
JRSCIntegraGSR is an unknown quantity at this point
Cam Question
I have a 95 GS-R with a JRSC. I have a stock head with a built bottom end. I am running 8lbs of boost and wanted to know which cams to go with. Don't want to change the valve train (just rebuilt head other than cams)
1995 Integra GSR- JRSC, Pulley Upgrade, Short Ram Intake, DC Header, Full Exhaust (NO FART CAN), Slotted Rotors, Stock Exterior
JRSCIntegraGSR is offline
Old 07-25-2007, 01:57 PM   #2 (permalink)
Cypher Wave
Transparent's Avatar
Car: I dont own a car
Mods: fuck off
your gsr intake is actually ideal for the jrsc. if you can pick up an itr exhaust cam youd be set
Transparent is offline
Old 07-26-2007, 04:00 AM   #3 (permalink)
I'd just spend the money elsewhere. Unless you want to go for it and be a test mule for everyone else on how much difference the cam makes for a SC application.
female four is offline
Old 07-26-2007, 08:18 AM   #4 (permalink)
Where elsewhere would you spend the money? From what I hear the skunk2 stage 1 is great for SC applications. But I was wondering if anyone else knew anything about it. I though about going to 10 or 12 lbs of boost but I worry about cooling problems. And that would cost ALOT more than a cam set up. But, I am up for suggestions!
Old 07-26-2007, 12:35 PM   #5 (permalink)
How much are the cams going to cost you? have you thought of that?
You can do a lot of other things.
  • LHT Intercooler
  • Header upgrade
  • Exhaust upgrade
  • Boost upgrade
Last I heard LHT also did a 4-5 belt rib pulley upgrade as well to prevent belt slippage. Depends on what you have now.
Old 07-26-2007, 02:08 PM   #6 (permalink)
  • LHT Intercooler
  • Header upgrade
  • Exhaust upgrade
  • Boost upgrade
-LHT Intercooler= more money for the same power
-Header upgrade= not much more power
-Exhaust upgrade= not much more power
-Boost Upgrade= need intercooler so that means way too much money
Cams= More performance for the dollar
Old 07-27-2007, 07:56 PM   #7 (permalink)
Car: 91 CRX Si
LHT will allow you to run more timing and with a tune you will make more power.
91 CRX Si
JRSC Turboedit ECU
Boost Upgrade Pulley
daveb91 is offline
Old 07-28-2007, 05:03 AM   #8 (permalink)
Whats the best company to get one from?
Old 07-29-2007, 03:55 AM   #9 (permalink)
Car: 03 RSX Type S
James777 has a spectacular aura aboutJames777 has a spectacular aura about
a lot of aftermarket cams increase the amount of overlap. in a boosted car this causes you to lose boost. you might want to look into nos. the intercooling effect will result in greater gains than on a NA car.
james.
James777 is offline
Old 07-29-2007, 05:39 AM   #10 (permalink)
Ummm, okay. Just get the cams and call it a day. I think I just wasted my time.
Old 07-30-2007, 07:24 AM   #11 (permalink)
Thanks for your help. I am just going to intercool it. You all have really helped and changed my mind. I was alittle set on cams but I think it just because I am use to n/a cars. Thanks again
Old 07-30-2007, 04:52 PM   #12 (permalink)
PickleTeg's Avatar
Car: 95 Integra SE
Mods: Most powerful JRSC LS in the world!
PickleTeg You need a lifePickleTeg You need a lifePickleTeg You need a lifePickleTeg You need a lifePickleTeg You need a lifePickleTeg You need a lifePickleTeg You need a lifePickleTeg You need a lifePickleTeg You need a lifePickleTeg You need a lifePickleTeg You need a life
It is not cheap but if you get the LHT and up the boost with a good tune you will love it I promise!
SSG, U.S. Army
Original TDP member
95 Integra SE
New A/C Synapse ramhorn kit 276 WHP, 210 WTQ
PickleTeg is offline
Old 07-30-2007, 10:06 PM   #13 (permalink)
Bl0wn Z6
ksniperfox's Avatar
Car: 90 rex si
Mods: JR edition GT killer
Originally Posted by James777
a lot of aftermarket cams increase the amount of overlap. \.
thats why you get FI cams. besides, overlap can always be solved with cam timing adjustments.
'90 crx Si
MY VIDEO(old setup)
Originally Posted by Snoopy
ksniperfox is offline
Old 07-31-2007, 04:30 PM   #14 (permalink)
Car: 91 CRX Si
To a certain point, mild NA cams can work.
91 CRX Si
JRSC Turboedit ECU
daveb91 is offline
Old 08-01-2007, 06:44 AM   #15 (permalink)
Dark Samurai
BlueBallz you're still here?BlueBallz you're still here?BlueBallz you're still here?BlueBallz you're still here?BlueBallz you're still here?BlueBallz you're still here?BlueBallz you're still here?BlueBallz you're still here?BlueBallz you're still here?BlueBallz you're still here?BlueBallz you're still here?
Are these LHT ahh..."pre-coolers" available for purchase?
Last time I talked to the dude it was still, like, a "basement
operation/testing" type of thing?
BlueBallz is offline
» Site Navigation
» Home
