Old 07-30-2007, 08:34 AM   #1 (permalink)
whity is an unknown quantity at this point
Methanol/injection question?
Hi!
I have problems with high IAT and that`s why i want to use methanol/water mixture to cool it down?
I`m boosting 9.5psi on my 94 delsol with b16a engine,but first pull is okey,i have a lot of power but then i get the IAT problems which rise up to 125deg.C or 257 degF,so i stop to pull and install M/I kit.
How are yours experiance with M/I?Is it really cooling down the IAT?Can somebody tell me what`s the best A/f ratio to run with M/I?
At how much boost is it the best to start to inject?
How much liter do you need for about 100km?I intend to use 50/50 mixture.
Thanks in advance.
whity is offline
Old 07-30-2007, 12:59 PM   #2 (permalink)
BurntRubber87's Avatar
BurntRubber87 has a Rep problemBurntRubber87 has a Rep problemBurntRubber87 has a Rep problemBurntRubber87 has a Rep problemBurntRubber87 has a Rep problemBurntRubber87 has a Rep problemBurntRubber87 has a Rep problemBurntRubber87 has a Rep problemBurntRubber87 has a Rep problemBurntRubber87 has a Rep problemBurntRubber87 has a Rep problem
Meth injection acts just like a chemical intercooler, it will lower intake temps drastically, it allows you to run more boost/more advanced timing on the same octane rating. When you buy a kit, it comes with everything you need, it comes on at pretty low boost..like under 5psi im pretty sure. Same A/F ratio as before, like between 10.5:1-12:1, its getting more popular because its pretty safe, you just have to make sure its always on, always has water/meth mixture, all the vacuum sources are secured because if something malfunctions and you're running more boost, more timing and all of a sudden the injection quits, i'm sure you can guess what happens.
BurntRubber87 is offline
Old 07-30-2007, 01:09 PM   #3 (permalink)
Car: 91 CRX Si
daveb91 In the rep tropospheredaveb91 In the rep tropospheredaveb91 In the rep tropospheredaveb91 In the rep tropospheredaveb91 In the rep tropospheredaveb91 In the rep tropospheredaveb91 In the rep tropospheredaveb91 In the rep tropospheredaveb91 In the rep tropospheredaveb91 In the rep tropospheredaveb91 In the rep troposphere
www.snowperformance.net
I am a member on there forums there they can answer all your questions.
One thing you have to member you are going to have to have this tuned for W/I. If not you will be running rich and you will actually loose power. A common complaint with people running it. I was told to inject right before the tb so it will also cool te SC components you will also gain.5-1 psi because the fluid makes the rotor tolerances closer. If you are tuning for W/I and you want 12:1 ratio you actually tune for 12.5:1 because the Methanol will lower it another .5 or so. I am going to go this route soon when I get some work don to the blower.
91 CRX Si
JRSC Turboedit ECU
Boost Upgrade Pulley
daveb91 is offline
Old 07-30-2007, 01:13 PM   #4 (permalink)
Car: 91 CRX Si
Also snow and I think other companies also have kits for eaton blowers if you are running some advanced timing with the W/M injection and you need a safe guard in such that if the W/M inj failed or clogged for some reason and your tune was so rad that it would harm your motor by going lean They have a module that has a solenoid that would open the bypass valve an therefore cutting boost so you dont harm the motor.
91 CRX Si
JRSC Turboedit ECU
daveb91 is offline
Old 08-21-2007, 09:55 PM   #5 (permalink)
Car: 2000 civic , non-vtec
RAYRUIZ In the stratusphereRAYRUIZ In the stratusphereRAYRUIZ In the stratusphereRAYRUIZ In the stratusphereRAYRUIZ In the stratusphereRAYRUIZ In the stratusphereRAYRUIZ In the stratusphereRAYRUIZ In the stratusphereRAYRUIZ In the stratusphereRAYRUIZ In the stratusphereRAYRUIZ In the stratusphere
honestly I would go for a LHT intercooler from LHTPERFORMCE.NET . If they still make the intercooler for my M45 , I would get one.
RAYRUIZ is offline
Old 08-21-2007, 10:46 PM   #6 (permalink)
Car: 91 CRX Si
Earlier this year i contacted LHT and they said yes they do make them but unlike the b series unit they are made by hand so it would take time. Then a couple months ago someone else contacted them and they said they no longer offer it. I have never got back with them so I cant confirm this.
91 CRX Si
JRSC Turboedit ECU
daveb91 is offline
Old 08-26-2007, 08:02 PM   #7 (permalink)
00LudeSH00's Avatar
Car: 2000 Prelude SH
Mods: JR Supercharger, OBD1 Conv., Crower Cams, Crower Springs, Crower Retainers, AEM Intake, VIS Carbon Fiber Hood, 18" Axis Mod7, Powerslot Rotors, BFGoodrich KDW,
00LudeSH00 Needs a boyfriend/girlfriend00LudeSH00 Needs a boyfriend/girlfriend00LudeSH00 Needs a boyfriend/girlfriend00LudeSH00 Needs a boyfriend/girlfriend00LudeSH00 Needs a boyfriend/girlfriend00LudeSH00 Needs a boyfriend/girlfriend00LudeSH00 Needs a boyfriend/girlfriend00LudeSH00 Needs a boyfriend/girlfriend00LudeSH00 Needs a boyfriend/girlfriend00LudeSH00 Needs a boyfriend/girlfriend00LudeSH00 Needs a boyfriend/girlfriend
I have 2000 supercharged prelude running on 6psi and i noticed quite a big difference and mine wasnt even fine tuned with the Snow Performance Boost Cooler. I went from actually a 14.6 to a 14.1 1/4 mile time. And that was just installing the kit. I got mine coming on as soon as i reach 95% throttle....I plan on tuning it this fall, i have the 9psi pulley just installed with crome so i can better tune it....
00LudeSH00 is offline
Old 08-27-2007, 02:43 AM   #8 (permalink)
Car: 91 CRX Si
you using windshield washer fluid? Also what nozzle size?
91 CRX Si
JRSC Turboedit ECU
daveb91 is offline
Old 08-27-2007, 11:40 AM   #9 (permalink)
Bl0wn Z6
ksniperfox's Avatar
Car: 90 rex si
Mods: JR edition GT killer
wtf are you talking about?
'90 crx Si
MY VIDEO(old setup)
Originally Posted by Snoopy
ksniperfox is offline
Old 08-27-2007, 02:04 PM   #10 (permalink)
Car: 91 CRX Si
I understand what he is talking about maybe you should learn more about W/M inj systems
91 CRX Si
JRSC Turboedit ECU
daveb91 is offline
Old 08-27-2007, 05:39 PM   #11 (permalink)
Bl0wn Z6
ksniperfox's Avatar
Car: 90 rex si
i know how w/mI kits work. but his grammar is all fucked up and its hard to make out what hes trying to say
'90 crx Si
MY VIDEO(old setup)
Old 08-27-2007, 05:47 PM   #12 (permalink)
Car: 91 CRX Si
LOL! Grammar? This is the internet! You cant even put in proper punctuation or capital letters.
J/K man
91 CRX Si
JRSC Turboedit ECU
daveb91 is offline
» Site Navigation
» Home
 > FAQ
» Other Sites
