hey i got my new job and i am getting the money in . i want to SC my 98ex with JRSC but is 115,000 miles to high to be boosting. i keep getting mixed answers.
only way to find out is a comp test and leakdown test. mileage means nothing
He's not Japanese, he was referring to the languages he can speak. He's capable of speaking English, can probably curse and ask for a beer in Spanish and has heard his girl moan in Japanese in bed
that was my argument to everyone that said the motor will blow apart. lol i said as long as its still good and compression is fine and has a good average they itll be fine. how do you do a leak down test. i already know how to do compression check.
Wrong. Thats a wet test as compared to a dry test that you normally do. A leak down test needs to actually have air into the compression chamber to see where and how much air is leaking. That is why its called a leak test.
for a leakdown test you need shop air pressure(110-150psi) and a hose adapter that fits into each spark plug. listen for leaks on each cylinder, as well as use a air pressure gauge to determine leakage. find and repair.
'90 crx Si
