Old 05-21-2007, 01:18 AM   #1 (permalink)
crunchtime2k is an unknown quantity at this point
Talking New JRSC owner d16y7 97 hatch dx
just installed my jrsc kit on my 97 dx hatch d16y7
runs OK, i will fine tune the fuel this week, plugs are showing signs of lean out
also using the jr map controller , did not use the lame relay.
i have a few questions.
Can i use my stock y7 crank pulley ? it looks a tad bit larger (more boost)
if so does anyone know what belt i need
and what kind of boost it would give,
Yes i SEARCHED 23 pages , and could not get any solid info.
Also my power on the low end seems low. it really likes to pickup on the topend and hit the revlimiter real fast. Any ideas? im thinking fueling right now.
Do you guys think it is worthwhile to replace the stock one peice exhaust manifold . cat combo hanging in front of the motor with a 4 -2 - 1 header?
It seems really restrictive to me.
Please give me any input.
Also can someone with my setup post some pics of how they did the throttle cable?
i just want to make sure i did it right. the instructions really sucked.
thanks
crunchtime2k is offline
Old 05-21-2007, 02:16 PM   #2 (permalink)
AcidLotus's Avatar
AcidLotus AcidLotus AcidLotus AcidLotus AcidLotus AcidLotus AcidLotus AcidLotus AcidLotus AcidLotus AcidLotus
Red face
I would definitely recommend the 4-2-1 header for sure, but I'm not sure if you can use the OEM crank pulley... you could try it, but the spacing might be off, thus possibly leading to premature belt wear, or worse, belt slippage and/or breakage at higher boost levels. Not sure on the throttle cable either, but good job going for the map controller vs. that lame relay!
2005 TSX 6MT + Navi
AcidLotus is offline
Old 05-22-2007, 12:21 AM   #3 (permalink)
Bl0wn Z6
ksniperfox's Avatar
Car: 90 rex si
Mods: JR edition GT killer
Y8 pulley is the largest D series pulley. forget the map controller. get real tuning.
'90 crx Si
MY VIDEO(old setup)
Originally Posted by Snoopy
ksniperfox is offline
Old 05-24-2007, 03:44 PM   #4 (permalink)
Car: 91 CRX Si
Y8-Y7 same thing I have had both. If you are showing signs of leaning I would not go with the bigger pulley till you were ready to get some real inj and managment.
91 CRX Si
JRSC Turboedit ECU
Boost Upgrade Pulley
daveb91 is online now
