Originally Posted by g3 integra ls
I have a 98 spec integra type r motor, and i just picked up a jrsc kit with a 8psi pulley for a good deal. I was wondering what you guys think of this combo? Is it worth doing? Will the motor be fine? Any advice you have please let me know. Thanks in advance,
Brandon
Should be OK but read the Guide to Supercharging sticky here and automatically plan for the "Higher Boost Setup" and/or "Project Standalone" right off the bat. The high compression of the Type-R demands that you get it tuned well with a competent dyno/ECU tuner. For your setup, I would highly recommend starting with the standalone ECU so that you can ditch the need for FMUs, jump up to bigger injectors, and get Walbro Fuel pump to supply everything. Once that is done, it will be fine and definitely worth doing. I still cherish the ride I got around the race track in a 5.5 PSI'd ITR to this day, and that was on the JR FMU. Now that better ECU technology is there to unleash more power safely, along with 8 PSI, you'd have quite the track screamer!
