Go Back   Honda Forum / Acura Forum - SuperHonda.com > SHO Media Center > Cameras & Photography
Old 03-16-2006, 10:30 PM   #1 (permalink)
Tadashi_Photo's Avatar
Car: 95 eg6 3d
Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!
Understand the Zone System
If you read the write up i completed about lighting I mentioned the use of the camera metering system and it’s problems there in. As I mentioned the light meter within the camera is known as an illumination light meter, meaning it measures the light being reflected from a subject.
The problem of using your metering on your camera is the fact that it meters the light being reflected from a surface. The reading you get will meter anything you point it at as 18% gray. If you point your camera at a white wall, your camera will render that white wall18% gray. if you point the camera at a black wall, your camera will render that black wall 18% gray. Where as if you used a incident light meter, which meters the light from the light source instead of the reflected light.
Now you properly use a built in camera light meter you must learn how to read that meter and know how to adjust for that.
Here we must know the zoning system:
Zone 0 - Pure black
Zone I - Black
Zone II - Black with detail andNO texture
Zone III - Black with detail and texture
Zone IV - Dark Gray
Zone V - Middle gray (18% gray)
Zone VI - Light gray
Zone VII - White with detail and texture
Zone VIII - White with detail and NO texture
Zone IX - White
ZoneX - Paperbase
Now we look at a simple problem to work out in your head.
If you point your camera at a white wall and get a meter reading through your camera. Your camera immediatly renders that walls 18% gray
remember 18% gray = Zone V
Now, in order for you to render that wall white with detail and texture, you want to move from Zone V to Zone VII
you must consider the different from one zone to another as 1stop of light.
so in order to move from Zone V to Zone VII you are moving 2 stops (or two zones).
so once you find that meter reading on your camera you will want to OVER EXPOSE the scene by 2 stops.
Now you have taken a photograph that is rendered properly...easy huh?
i’ll leave you something to do on your own just so you can try it out
Now consider that you are photographing a black wall. When you point your camera at that wall your camera renders that wall 18% gray.
18% gray is what zone? _____
Now you want to render that wall black w/ detail and texture from 18% gray.
According to the zones you would be moving 2 zones.
So you would want to under expose the scene by how many stops? _______
There you go if you understood that then you now know how to properly use your built in light meter in your camera.
The answers are below.
Answers:
Q. 18% gray is what zone?
A. Zone V (5)
Q. According to the zones you would be moving 2 zones.
A. 2 stops
Tadashi_Photo is offline
Old 02-15-2007, 11:12 AM   #2 (permalink)
bobbinika's Avatar
Car: 01 Integra Type R
bobbinika you're still here?bobbinika you're still here?bobbinika you're still here?bobbinika you're still here?bobbinika you're still here?bobbinika you're still here?bobbinika you're still here?bobbinika you're still here?bobbinika you're still here?bobbinika you're still here?bobbinika you're still here?
just a note
expose for shadows, develope for highlights
bobbinika is offline
» Site Navigation
» Home
 > FAQ
» Other Sites
