Go Back   Honda Forum / Acura Forum - SuperHonda.com > SHO Media Center > Cameras & Photography
Old 02-25-2004, 02:48 PM   #1 (permalink)
Car: 96 civic LX
Primax has a spectacular aura aboutPrimax has a spectacular aura about
Understanding aperture, shutter speeds and exposure
So you've got your new camera and you wanna experiment with manual settings do you? Well before you go shoot those pics theres a few things you should know so you have some idea of what your doing and why your doing it. Most SLR's and mid to high end digital cameras have your basic to advanced manual settings. Usually these consist of choices M for full manual, A for aperture priority, and S for shutter priority.
Aperture and shutter speed are the main things you need to know in order to get the correct exposure and depth of field(dof). Aperture determines how much light hits the film and shutter speed determines how long its exposed.
On your digital camera there may be several choices of aperture settings of f2, f2.8, f4, f5.6, f8, f11, f16, f22, and f32, with f2 being the largest and f32 the smallest(yea, i know it sounds backwards). Some cameras differ and many dont have all these choices but you just have to work with what u have. Each f# is called a stop. Each stop up doubles the amount of light which is allowed in the camera. Example, f5.6 lets in double the light as f8, etc.
Besides controlling light, aperture also controls dof like i said before. This is the amount of area in front of and behind the subject that appears in sharp focus. The larger the aperture, the smaller the dof. Example, f22 may have the entire picture in focus which f2.8 will only have the subject and maybe a little area around the subject in focus.
Shutter speeds determine the time of how long the shutter is open. Most digi cams with shutter adjustment go anywhere from 1/2000second to 30seconds. Just like aperture, each speed slower, doubles the amount of light. Example, shutter set at 1/125second will be twice as bright as shutter at 1/250second. Both have their advantages and disadvantages. If you were too take a picture of a car driving by you would need a high speed of say 1/250th of a second. Maybe a little slower if you wanted that wheel in motion look. For most action anything over 1/60 will work fine. Any speed below 1/30 will more than likely need a tripod as any motion in the photographers hand will result in a blurred picture. This is exactly why a tripod is so crucial in taking night pics.
Now that you understand aperture and shutter speed, we can move on to exposure. Most cameras have automatic exposure systems which usually work perfect and provide properly exposed pictures. When these systems dont work is when there is extreme lighting conditions, such as a persons face with a bright snowy background. This sort of scenario would trick the camera into turning down the exposure for the bright snow which would result in the darkening of the main subject, the persons face. This is known as overexposure. To avoid this, you should decrease the aperture by a stop or two from what the camera tells you and maybe even turn on the flash to compensate for the dark shading.
A picture take with a dark background and a lit up face might have the opposite problem and the camera might over compensate by underexposing the image which would result in the face being too light because the camera was trying to detail the background and not the subject. To avoid this just do the opposite as you would for overexposure.
These are the basic things you need to know about aperture, shutter speed and exposure. Eventually i will try and get some pictures to go along but for now, you'll have to cope with me and i hope this helps out in learning why the camera does these things and what you can do to take better pictures. If you have any questions, feel free to ask.
010100000111001001101001011011010110000101111000
Primax is offline
Old 02-25-2004, 03:56 PM   #2 (permalink)
Super Moderator
5genlude's Avatar
Car: 2001 PRELUDE 5spd
Mods: Short Ram Intake, Neuspeed Sport Springs, LEAN true short shifter, VAFC, VIS oem style cf hood
5genlude you're still here?5genlude you're still here?5genlude you're still here?5genlude you're still here?5genlude you're still here?5genlude you're still here?5genlude you're still here?5genlude you're still here?5genlude you're still here?5genlude you're still here?5genlude you're still here?
Excellent Write up/Article. Stuck.
5genlude is offline
Old 02-25-2004, 10:13 PM   #3 (permalink)
Lifeless Ninja
civperc's Avatar
BOOYA. good stuff. very good stuff.
Advertise on Superhonda
civperc is offline
Old 04-30-2004, 09:35 PM   #4 (permalink)
Digital Drifter
Car: 1997 Honda Prelude
Mods: Apex'i WS exhaust. MSD wires. Denso Iridium Plugs. Exedy clutch
MrBB6 has much to be proud ofMrBB6 has much to be proud ofMrBB6 has much to be proud ofMrBB6 has much to be proud ofMrBB6 has much to be proud ofMrBB6 has much to be proud ofMrBB6 has much to be proud ofMrBB6 has much to be proud of
It's Funny. I took a full semester of B&W Photo in college and i learned more reading this little thread than i did from that whole class. Heh, Tuition money at it's finest!!
MrBB6 is offline
Old 08-24-2004, 03:01 PM   #5 (permalink)
untouchable
Car: 93 Accord Coupe
uncle_el is a name known to alluncle_el is a name known to alluncle_el is a name known to alluncle_el is a name known to alluncle_el is a name known to alluncle_el is a name known to all
just got a digital camera a few days ago, and had been wondering how to better learn about the features in a way other than experimenting with the camera. thanks for the write up.
uncle_el is offline
Old 08-24-2004, 03:55 PM   #6 (permalink)
Super Moderator
5genlude's Avatar
No doubt, this guy knows his stuff, he is a very gifted photographer. Also do not forget, use your camera's manual to figure out how to change settings properly, and what modes/settings you have in your camera. Also the manual will tell you a little about shutter speeds and aperature, just in generalized form, after u read that, read this again, you'll understand it even better and maybe start off the cool hobby of photography
5genlude is offline
Old 08-24-2004, 04:51 PM   #7 (permalink)
untouchable
read the owners manual before reading this . one step ahead of you.
but yes, primax takes great photos, as do you- after all, your the king of sigs around here!
uncle_el is offline
Old 08-24-2004, 05:10 PM   #8 (permalink)
Super Moderator
5genlude's Avatar
im not king , heheh, glad u took the initiative man, alot of people leave that manual in the box and just start guessing and taking crappy pics, some people, like u , take it on their own, anyways, appreciate ur kind remarks to the thread and i, primax is the man.
aznkid also can take badass pics.
5genlude is offline
Old 06-03-2005, 04:08 PM   #9 (permalink)
Car: 99 A4 1.8t / nissan maxima
weKILLyou Needs to go outside once in awhileweKILLyou Needs to go outside once in awhileweKILLyou Needs to go outside once in awhileweKILLyou Needs to go outside once in awhileweKILLyou Needs to go outside once in awhileweKILLyou Needs to go outside once in awhileweKILLyou Needs to go outside once in awhileweKILLyou Needs to go outside once in awhileweKILLyou Needs to go outside once in awhileweKILLyou Needs to go outside once in awhileweKILLyou Needs to go outside once in awhile
and knowing'shalf the battle GI joe!
weKILLyou is offline
Old 08-04-2005, 10:06 PM   #10 (permalink)
Car: 1996 Civic Vti
Mods: Basic stock EUROPEAN setup
testdrive will become famous soon enoughtestdrive will become famous soon enough
for those who want to learn more about using their digicams, please click on the link: http://www.canon.co.jp/Imaging/enjoydslr/index.html
hope this helps!
MAKE THAT MOVE...RIGHT NOW BABY!!!
testdrive is offline
Old 08-04-2005, 10:19 PM   #11 (permalink)
Super Moderator
5genlude's Avatar
hope this helps!
VERY VERY EXCELLENT POST, people read that site and learn it. great way to learn cameras
5genlude is offline
Old 08-12-2005, 03:15 PM   #12 (permalink)
tofuspeedstar's Avatar
Car: '98 Integra GS.
Mods: JDM Frontend, Gunmetal housing headlamps, UDKM Tails, Slammed on JIC FLT-2 Coilovers, 16x7 XX-Rs, Unorthodox Pulleys, AEM Shortram intake, Buddy Club Shortshifter, Spoon shiftknob, ARC Radiator Cap, buncha JDM heat on the way.
tofuspeedstar needs rep therapytofuspeedstar needs rep therapytofuspeedstar needs rep therapytofuspeedstar needs rep therapytofuspeedstar needs rep therapytofuspeedstar needs rep therapytofuspeedstar needs rep therapytofuspeedstar needs rep therapytofuspeedstar needs rep therapytofuspeedstar needs rep therapytofuspeedstar needs rep therapy
I hab teh good Idea, we's goin to teh hooka lounge tonight.
In depression, faith in deliverance, in ultimate restoration, is absent. the pain is unrelenting and what makes the condition intolerable is the foreknowledge that no remedy will come. It is hopelessness even more than pain that crushes the soul.
Need JDM goods? Send a PM w/ what your looking for.
tofuspeedstar is offline
Old 01-12-2006, 12:52 PM   #13 (permalink)
Car: 2003 Honda accord I4 LX
Mods: So far, K&N filter, Tornado system, and 2.25 piping with thermal muffler
terrylee79 Hello down there miniscule peonsterrylee79 Hello down there miniscule peonsterrylee79 Hello down there miniscule peonsterrylee79 Hello down there miniscule peonsterrylee79 Hello down there miniscule peonsterrylee79 Hello down there miniscule peonsterrylee79 Hello down there miniscule peonsterrylee79 Hello down there miniscule peonsterrylee79 Hello down there miniscule peonsterrylee79 Hello down there miniscule peonsterrylee79 Hello down there miniscule peons
Good write up. I learned more from your write up than the manual book they had. I Just bought the fuji A350 yesterday haven't played around with the manual settings yet. Good write up.
edit: I traded the fuji to a canon a610 so I can play with the settings more
Straights are for cars, corners are for drivers.
2003 Honda accord I4.
Customized cold air intake
2.25 custom piping with thermal muffler
Eibach sportlines
Koni yellow shocks
terrylee79 is offline
Old 01-23-2006, 11:31 PM   #14 (permalink)
Tadashi_Photo's Avatar
Car: 95 eg6 3d
Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!
then you can learn even more if you want.
stops work in 1/3's
here are a list of all the stops working 1/3's
1, 1.1, 1.3, 1.4, 1.6, 1.8, 2, 2.2, 2.5, 2.8, 3.2, 3.6, 4, 4.5, 5, 5.6, 6.4, 7.1, 8, 9, 10, 11, 12.5, 14, 16, 18, 20, 22, 25, 29, 32, 36, 40, 45, 51, 57, 64, etc
hahahah
enjoy
Tadashi_Photo is offline
