Go Back   Honda Forum / Acura Forum - SuperHonda.com > Honda - Vehicles > Type-R Forum
Old 08-13-2007, 05:27 PM   #1 (permalink)
Car: Honda Accord Type-S 2006
Mods: a few.
h1coupe Rep God/Goddessh1coupe Rep God/Goddessh1coupe Rep God/Goddessh1coupe Rep God/Goddessh1coupe Rep God/Goddessh1coupe Rep God/Goddessh1coupe Rep God/Goddessh1coupe Rep God/Goddessh1coupe Rep God/Goddessh1coupe Rep God/Goddessh1coupe Rep God/Goddess
99ITR turbo 12.36sec@111.93mph
a friend of mine has a 99 ITR. he has added the following mods.
drag gen 3kit.
T3/T4 Turbo.
255Walbro.
450dsm injectors. (rc 750 going in tomorrow)
PLX R-500 datalogger.
PLX Air/Fuel Ratio gauge.
Standalone from Autronic.
OBX boost gauge.
OBX fuel rail.
OBX exhaust.
AEM Pulley.
Aem Cam Gears.
Skunk2 70MM Throttle Body.
Brian Crower Stage 2 turbo cams with Valve Spring/Retainer KIT.
Fidansa Flyweel.
ACT Stage 3 clutch.
MSD wires.
MSD 6al ignition box.
MSD blaster 2 ignition coil.
MSD distributor cap and rotor.
C-Pillar bar.
Apexi BOV.
Front mount intercooler.
NGK irridium plugs.
K&N filter.
Energy Suspension Shifter bushings and engine mount inserts.
Ingalls Engine Torque Damper.
Mickey Thompson 24x8x15 slicks.
he is @12psi. and he went 12.36sec@111.93mph with a 1.798sec 60ft.
mid mph 88.41mph, 1/8 7.945sec.
the car weighs the stock 1150kg(2535lbs) and he weighs 90kg(198lbs)
total weight 1240kg(2733lbs)
he just went to have to car dynoed and it came out @255whp. that canīt be can it? we thought it was closer to 280-300whp? anybody know of anyone running similar times and what they are putting down?
ī06 Euro Accord Type-S
Hondata reflash
K&N cai
ebay ss header
Comptech springs
Comptech Rear sway bar w/esb
Bridgestone potenza re070
Alpine Type-S 6x9"
awaiting install
Hondata IMG
P2R thermal gasket
Ingalls ETD
NST pulleys.
06SI gears+final drive and lsd.( 1st and 2nd gear were bad, so all I could use was the lsd )
EP3 CTR flywheel 4.7kg(couldnīt use it cause I didnīt have a civic clutch to put in with it )
h1coupe is offline
Old 08-28-2007, 11:53 AM   #2 (permalink)
The Todd's Avatar
The Todd The Todd The Todd The Todd The Todd The Todd The Todd The Todd The Todd The Todd The Todd
Pretty quick for a simple setup.
The Todd is offline
Old 08-28-2007, 11:32 PM   #3 (permalink)
idunno1's Avatar
Car: 98 prelude
Mods: 18 psi
idunno1 Rep God/Goddess with nothing better to doidunno1 Rep God/Goddess with nothing better to doidunno1 Rep God/Goddess with nothing better to doidunno1 Rep God/Goddess with nothing better to doidunno1 Rep God/Goddess with nothing better to doidunno1 Rep God/Goddess with nothing better to doidunno1 Rep God/Goddess with nothing better to doidunno1 Rep God/Goddess with nothing better to doidunno1 Rep God/Goddess with nothing better to doidunno1 Rep God/Goddess with nothing better to doidunno1 Rep God/Goddess with nothing better to do
255whp =12.3
something is wrong
p
idunno1 is offline
Old 08-29-2007, 02:17 AM   #4 (permalink)
Mods: a few.
Originally Posted by idunno1
255whp =12.3
something is wrong
thatīs what we thought.
that dyno bench has been handing out some weird readings.
must be broken.
Hondata reflash
K&N cai
ebay ss header
Comptech springs
Alpine Type-S 6x9"
awaiting install
Hondata IMG
P2R thermal gasket
Ingalls ETD
NST pulleys.
h1coupe is offline
Old 09-01-2007, 09:44 PM   #5 (permalink)
flextour's Avatar
Car: <ivi> hatch 1993 SiR
Mods: B16a2, CAI, OBX headers and straight pipe, SRR cam gears...
flextour In the rep troposphereflextour In the rep troposphereflextour In the rep troposphereflextour In the rep troposphereflextour In the rep troposphereflextour In the rep troposphereflextour In the rep troposphereflextour In the rep troposphereflextour In the rep troposphereflextour In the rep troposphereflextour In the rep troposphere
kudos to u.... great set up boss!
FLYING REALLY LOW IN JAMAICA 4 DOOR TYPE R NOW
flextour is offline
Old 10-18-2007, 03:46 PM   #6 (permalink)
Car: 92 EG
Mods: Riding Low
Hypnotikefx You need a lifeHypnotikefx You need a lifeHypnotikefx You need a lifeHypnotikefx You need a lifeHypnotikefx You need a lifeHypnotikefx You need a lifeHypnotikefx You need a lifeHypnotikefx You need a lifeHypnotikefx You need a lifeHypnotikefx You need a lifeHypnotikefx You need a life
go here you will find out everything, i love this site
http://www.tunercalcs.com/
Hypnotikefx is offline
Old 10-19-2007, 02:30 PM   #7 (permalink)
ITR-tist's Avatar
Car: JDM '96 Integra type R 4-door
Mods: Shift knob, pedals, Short Ram Intake
ITR-tist You need a lifeITR-tist You need a lifeITR-tist You need a lifeITR-tist You need a lifeITR-tist You need a lifeITR-tist You need a lifeITR-tist You need a lifeITR-tist You need a lifeITR-tist You need a lifeITR-tist You need a lifeITR-tist You need a life
Maybe its the atmospheric conditions...is the dyno on top Mt Everest or something?
HONDA...
KICKIN'
SINGLE TURBOTWIN-TURBOSUPERCHARGEDNITROUS-OXIDEBIG-BLOCKFLAT-FOURI-6/V-6/V-8
ASS
SINCE 1954.
ITR-tist is offline
Old 10-19-2007, 02:34 PM   #8 (permalink)
Car: 94 del sol si
Mods: Its getting there
macneilsoberide is a splendid one to beholdmacneilsoberide is a splendid one to beholdmacneilsoberide is a splendid one to beholdmacneilsoberide is a splendid one to beholdmacneilsoberide is a splendid one to beholdmacneilsoberide is a splendid one to beholdmacneilsoberide is a splendid one to behold
thats really low power for an itr motor on 12psi i seen stock b16s make more than that with the shitty b16 cams.
macneilsoberide is offline
ŧ Wheel & Tire Center
