CST ZERO-1 damper Civic Type R(EK9)
● Camber adjustment F: × R: ×
● Spring rate F: 12kg/mm R: 8kg/mm
● Unprecedented low down was enabled by using full length adjustment-type (a full tap) car high pitch Hitoshi kit super shortstop case. In addition, I take strong special coating to be rusted in the main body of case.
● 15 steps of single pipe-style decrement power adjustment
A decrement power part of a car high pitch is established by an upper mount department. I become 15 phases of front and back adjustment.
alizes the merit that there becomes little friction to lower it than a general thing.
If you see the picture please email with us and i will show you the picture.
Email:tao.enterprise.co@kitty.jp
