I found out that the 02-03 Civic Si rear brake system is the same as the RSX and ITR. The Civic uses the 4 x100 while the RSX has the 5 bolt pattern.
This means that the RSX rear calipers can bolt on the 90-2001 Integras, if you use either A) the Civic Si rear rotors, or B) use the ITR/RSX rotors with the 4 x100 pattern drilled in them.
The Si/RSX rotors are 10.25, up from 9.4 on the Teg.
The Civic Si rear brakes will bolt right on the Integra too, but I don't know how many of them will be available so the RSX would be the best place to get the calipers. The only difficulty will be the parking brake cables have a different end on them now, they slip over the lever, rather thatn using a pin like the Integra. The cable will have to routed a little differently too since the lever pulls down instead of forward on the Teg.
Cliffnotes:
You can get the rsx or ep3 rear caliper and get the ep3 rear discs and have the same rear breaking system as the integra type R. Your gsr front rotor won't fit the rear caliper because it's vented, not solid.
