Need OBD II B18C distributer yeasterday!
Wifes B18C OBD II distributer gave up and no local shops/dealers have them... anyone in the Central TX area have one they want to sell?
OBD II DOHC B16 will work also...
Sorry for the post guys, but need to have it running by tomorrow... Rental car places seem to be closed unless your an insurance agency...
1998' 4dr GSR, 8psi JRSC w/hand ported plenum, 320cc injectors, Cartech adj. FMU, Walbro HP fuel pump, TPS trick in the works, valves set to .005i/.006e, MSD BTM, B&M CommandFlo regulator, stock intake w/ITR "cool air" resinator, Greddy sp exhaust, Tokico Illumina 5-ways, ITR springs, Skunkworks 22mm rear swaybar(removed due to mount torn out at present), ES motor mounts and front swaybar bushings, 205/50WR/15 Kumho Supra 712s, KVR Carbon Fibre pads, Super blue dot 4 brake fluid, B&M fuel pressure gauge, Autometer sport comp A/F gauge in dimmer location...
PY 00' Type R #00-1011 with "special tuning" and 143db triple air horns
Honest officer, I had no idea how fast I was going...the speedometer only gos to 150...
