Go Back   Honda Forum / Acura Forum - SuperHonda.com > Honda - Vehicles > Jazz . Fit Forum
Old 09-08-2006, 08:33 PM   #1 (permalink)
marokero's Avatar
Car: 2007 Fit
Mods: Spoon Sports SW388 16x7
marokero has a spectacular aura aboutmarokero has a spectacular aura aboutmarokero has a spectacular aura about
modified JDM center roof storage console
It took some doing but I got it working perfectly. I'll let the pics do the talking and I'll write some brief explanations of each image:
This is a shot of the Radio Shack brand magnetic switch partly disassembled (it's the normally open type).
Hot-glued the magnet to the inside rotating tray of the storage console.
Partly disassembled storage console to show where magnet was attached.
This is one of the led's already in its holder, secured in the hole I drilled through the console. I wanted to drill at an angle, but then the led holder wouldn't clear the tray when it swung closed.
Here's a shot from the other side, the led holder screwed and crazy-glued in place
I hot-glued the magnetic switch to the back of the console, aligned with the magnets position. Once the magnet swings 1.25" away from the switch the normally open switch closes and turns on the leds as the tray goes down.
Here I soldered two resistors (330ohm and 10ohm in series to make a 340ohm resistor). This should limit the voltage getting through to the led's, which in the Radio Shack package called for 3.6V and 20mA each. I put the resistors on the positive side of circuit as that is how I saw on an online diagram I found.
Leds are wired (in parallel). Notice the grooves, they are for a separating wall.
The separating wall is placed back in position.
This is how it looks installed. I didn't have someone to help out, so I could not get a shot of the wiring hack that I did under there. I basically cut the positive (red/white) lead to the ceiling light, stripped the ends and used a wire nut to joint the positive leads together. The other wire from my contraption doen't get hooked to the other lead wire (green/red), instead it needs to be grounded. I stripped the end of the wire and ran the copper lead through the screw hole on the metal support bracket (see Ben's post on FitFreak.net for a picture). When I screwed the ceiling light assembly back in place the wire was securely grounded in place. Now for a test. Drum roll please...
Okay, so it's day time and the light from the leds is barely visible
People wanted to see how the center storage console looked with the tray and the read door opened, so here it is
Okay, here it is the console with one of the leds turned on (now that it's gotten darker outside).
A wider view. Notice I put a white plastic film on the inner walls so the white light from the led would reflect just a little better than with the gray, textured plastic of the console.
One last pic to show just how much the leds illuminate.
It took a lot of work, I got my fingers burnt by the soldering iron (it was 4am, what do you expect?), had to consult with my dad overseas regarding the resistance value for the resistors (thank God for Skype ), I accidentally marred inner walls of the tray while drilling/widening the holes (the plastic film served a dual purpose ), but the end result gives the Fit a more upscale look I think
Alberto T., PPA
Stuff from Spoon Sports, Yokohama, GTSpec and J's Racing
marokero is offline
Old 09-09-2006, 06:05 AM   #2 (permalink)
Sex offender
NaPPyDUgout01's Avatar
Car: 01 MR-2
Mods: Twin Space Doo Doo Pistols
NaPPyDUgout01 Bow down before me!NaPPyDUgout01 Bow down before me!NaPPyDUgout01 Bow down before me!NaPPyDUgout01 Bow down before me!NaPPyDUgout01 Bow down before me!NaPPyDUgout01 Bow down before me!NaPPyDUgout01 Bow down before me!NaPPyDUgout01 Bow down before me!NaPPyDUgout01 Bow down before me!NaPPyDUgout01 Bow down before me!NaPPyDUgout01 Bow down before me!
hey good job thats a pretty sweet DIY
"You say you hate the shade of my face for my Father's share crops , but my people were slaves before yours invented hip-hop"
Reppin the 817
NaPPyDUgout01 is offline
Old 09-09-2006, 08:55 AM   #3 (permalink)
marokero's Avatar
Car: 2007 Fit
Thanks NaPPyDUgout01! I should stop by my dealer just to show my salesman this install. The storage console is not a NADM option right now, so it would be interesting to see his reaction. He took a picture of my Fit after I put rims on (the same day I took posession) and used it for his desktop background in the dealership
Alberto T., PPA
marokero is offline
Old 09-11-2006, 07:48 AM   #4 (permalink)
theflipimage's Avatar
Car: '97 Honda Civic DX Hatchback
Mods: 10 years and 320,000 miles later and still no engine swap yet...
theflipimage needs rep therapytheflipimage needs rep therapytheflipimage needs rep therapytheflipimage needs rep therapytheflipimage needs rep therapytheflipimage needs rep therapytheflipimage needs rep therapytheflipimage needs rep therapytheflipimage needs rep therapytheflipimage needs rep therapytheflipimage needs rep therapy
your sleeping patterns truly puzzle me...
it's been how many years since we were in college?
get some sleep!
you might fall asleep at the wheel on your way to another photo shoot!
Remember: side-view mirrors are SUPPLEMENTARY to looking over your shoulder.
Enough with the EXCUSES. Let's go AUTOCROSSING!
theflipimage is offline
Old 09-11-2006, 09:30 AM   #5 (permalink)
marokero's Avatar
Car: 2007 Fit
When I'm concentrated on something I can't sleep But I do sleep when I'm tired... like last week I slept from 11:30pm (unheard of!) until 8am. For me that's a lot of sleep
Alberto T., PPA
marokero is offline
Old 09-11-2006, 01:29 PM   #6 (permalink)
ghibli99's Avatar
Car: 08 GD3 5MT
Mods: I'm for 'em.
ghibli99 is just really niceghibli99 is just really niceghibli99 is just really niceghibli99 is just really niceghibli99 is just really nice
Not only am I a noob, but I'm a Fit noob, too. That looks pretty good... what's up there normally in its place?
-Mike
08 GD3 5MT (VBP Sport)
Honda Access | Spoon | Mugen | T1R | PIAA | BFGoodrich
ghibli99 is offline
Old 09-11-2006, 01:47 PM   #7 (permalink)
empty space...
like the contents of my head today...
» Site Navigation
» Home
 > FAQ
» Other Sites
