Go Back   Honda Forum / Acura Forum - SuperHonda.com > Honda Racing > Part Review > Intake
Old 07-27-2004, 09:14 PM   #1 (permalink)
Car: 1998 Honda Accord EX 4cyl Sedan
Mods: see http://members.rankmyride.com/curtisaccord
CurtisAccord has a little shameless behaviour in the past
AEM Short Ram Intake
This was for my 1998 Honda Accord EX Sedan 4cyl:
I purchased the Chrome style AEM Ram Air Intake for my 98 Honda Accord EX 4cyl. I'm going for the basic I/H/E setup to get better gas mileage. I currently have a Tsudo Cat-Back Fireball Exhaust system and the AEM RAI. I have seen about a 20 more miles per tank increase.
My exaust system is fairly loud so you can only hear the intake when you start climbing a hill or acclerate moderatly. It makes that little whistling sound. Also the engine now goes "WHAAAA" instead of "VRMMMMM" when you get on it, if you know what i mean... lol
The HP increses are probibly minimal. I noticed a small difference but remember its just a pipe and a filter.
When I was installing my intake i also removed the resonator (witch is not required). This will allow some more air to travel into the engine bay near the filter so cooler air will enter.
Installation was fairly easy. Took me about 3 hrs (because i removed the resonator witch requires removing the front bumper). I would say that I work fairly slow because i'm very careful about damaging anything else.
Also to get better gas mileage reset your ECU while installing this. First you disconnect the battery (both terminals). Then remove the Hazard fuse located in the engine bay area. When you are done installing the intake, replace the fuse and connect the battery. Then start the car and let it IDLE for 10 minutes. This will reconfigure your cars Air/Fuel ratios. Don't touch the gas while its doing that. Then shut it off and start back up, your ready to go!
Strengths:
-Looks nice in the engine bay
-Gives a few more HP
-Remove the resonator for cooler air
-Cool whistle while accel. (had friends think it was a turbo...lol)
-Sounds like a racing motor when you floor it!
-Better than generic (you get all parts, a few extras, specially coated inside pipe for better airflow, and High Quality AEM lubed filter
-Get all I/H/E for max gasmileage/HP
Weaknesses:
-May have to scoot the battery over to make room for the big filter
-Sometimes requires bending/relocating an A/C line that is in the way (I just put a nice rubber pad around it and set the intake on top)
CurtisAccord is offline
Old 07-28-2004, 09:59 AM   #2 (permalink)
mad-ass's Avatar
Car: 1995 Nissan 240sx
Mods: Circuit Sports Exhaust/5 lug hubs/RUCA/front strut tower bar/V2 Short Shifter, Stance GR+, Techno Toy Tuning Subframe Collars/TC Rod, Welded Diff, Z33 Inner/SPL v5 outter Tie Rod, White line rear sway bar, 5spd conversion
mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?mad-ass you're still here?
nice write up!
I do have a short-ram intake, but i think it's necessary to have the A/C pipe line seal/protected, other wise, it rattles like crazy on my car.
thanks for the ECU reset. didn't know that part. mind if you PM me for further more details? thanks!
My S14 Build Thread
mad-ass is offline
Old 08-22-2004, 10:03 PM   #3 (permalink)
ladron is an unknown quantity at this point
I have an AEM short ram on my teg and I love it. Quiet until you stomp on the gas, then it growls.
ladron is offline
Old 08-28-2004, 08:43 PM   #4 (permalink)
fr3nz33's Avatar
Car: 1999 audi a4 quattro turbo
Mods: what's a "modification?"
fr3nz33 is a rep whorefr3nz33 is a rep whorefr3nz33 is a rep whorefr3nz33 is a rep whorefr3nz33 is a rep whorefr3nz33 is a rep whorefr3nz33 is a rep whorefr3nz33 is a rep whorefr3nz33 is a rep whorefr3nz33 is a rep whorefr3nz33 is a rep whore
Word, in my 5g3n accord, it's great, sounds stock, till you stomp! i don't need the higher end power, i'm not racing, but for passing cars, and "spirited" driving it's absolutely perfect!
i'm in your head, i'm not here...
fr3nz33 is offline
Old 11-29-2004, 03:14 AM   #5 (permalink)
MugenLX's Avatar
Car: 98 honda civic
Mods: sittin on konig troubles, 96 integra LS swap, victor x intake mani, dc 4-2-1 header, short ram intake, custom exhaust, hayame muffler
MugenLX will become famous soon enough
i put a breather filter on my short ram and it sounds like a cricket is in my hood when i gas it...i think its the breather filter vibrating off my hood though...sounds good at wide open throttle
[98 Civic LX 4dr.]
96 B18B swap
Victor X intake manifold
DC 4-2-1 Header
custom exhaust
hayame muffler
MugenLX is offline
Old 11-29-2004, 11:29 AM   #6 (permalink)
Car: 2003 Honda accord I4 LX
Mods: So far, K&N filter, Tornado system, and 2.25 piping with thermal muffler
terrylee79 Hello down there miniscule peonsterrylee79 Hello down there miniscule peonsterrylee79 Hello down there miniscule peonsterrylee79 Hello down there miniscule peonsterrylee79 Hello down there miniscule peonsterrylee79 Hello down there miniscule peonsterrylee79 Hello down there miniscule peonsterrylee79 Hello down there miniscule peonsterrylee79 Hello down there miniscule peonsterrylee79 Hello down there miniscule peonsterrylee79 Hello down there miniscule peons
I had a short ram on my 97 teg ls. Felt better throttle response and little bit more power on the mid range. Overall it was a ok product.
Straights are for cars, corners are for drivers.
2003 Honda accord I4.
Customized cold air intake
2.25 custom piping with thermal muffler
Eibach sportlines
Koni yellow shocks
terrylee79 is offline
Old 12-15-2004, 12:41 AM   #7 (permalink)
Tadashi_Photo's Avatar
Car: 95 eg6 3d
Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!Tadashi_Photo Um, 1 million? Damn!
I've got the polished Red AEM intake and it's awesome.
noticed a small increase in acceleration in the higher band of RPMs.
at idle it sounds like theres a vacuum cleaner under my hood and when you stomp the gas you get a nice sucking sound (for lack of better words haha)
Tadashi_Photo is offline
Old 01-23-2005, 07:04 PM   #8 (permalink)
Car: 1999 INTEGRA GSR
ruffryder744 is a splendid one to beholdruffryder744 is a splendid one to beholdruffryder744 is a splendid one to beholdruffryder744 is a splendid one to beholdruffryder744 is a splendid one to beholdruffryder744 is a splendid one to beholdruffryder744 is a splendid one to behold
i have an aem sri on my gsr... great intake right here... quiet until you get on the car and this thing sounds amazing when vtec kicks in
1999 Milano Red Integra GSR :clap
ruffryder744 is offline
Old 01-31-2005, 02:55 PM   #9 (permalink)
mugen_type_r's Avatar
Car: 2007 E90 328i
mugen_type_r has a reputation beyond reputemugen_type_r has a reputation beyond reputemugen_type_r has a reputation beyond reputemugen_type_r has a reputation beyond reputemugen_type_r has a reputation beyond reputemugen_type_r has a reputation beyond reputemugen_type_r has a reputation beyond reputemugen_type_r has a reputation beyond reputemugen_type_r has a reputation beyond reputemugen_type_r has a reputation beyond reputemugen_type_r has a reputation beyond repute
i have it on my civic as well, sounds really cool, but don't feel anything.
4 Doors are the best!!
2007 BMW E90 328i
Retired:
1999 Honda Civic 4dr
mugen_type_r is offline
Old 04-07-2005, 07:16 PM   #10 (permalink)
kommon_sense's Avatar
Car: 98 Civic Ex Coupe
Another review : Review of AEM short ram intake
kommon_sense is offline
Old 04-21-2005, 11:29 AM   #11 (permalink)
DV8
Car: 2k2 NBP AV6
Mods: Not telling! :)
DV8 is an unknown quantity at this point
Pro: HP increase... (doesn't feel it), lifetime filter
Con: Farting sound when shutting off your car, loud hissing when you drive your car before warming up.
02 Accord V6 Black
A few Mods
"What I do today must be important because I'm paying for it with my time.
What I do today must be worthy, because the price is high."
DV8 is offline
Old 04-21-2005, 10:41 PM   #12 (permalink)
mad-ass's Avatar
farting sound when u shut the car off?
mine just hisses at me when it shuts off.
My S14 Build Thread
mad-ass is offline
Old 04-22-2005, 08:16 AM   #13 (permalink)
DV8
Car: 2k2 NBP AV6
lol it's a hiss that sounds like fart.... but it's really embarassing sometimes, cause everyone thought my car was dying... lol
Oh and I also have a Helix TB spacer, that makes it louder too
02 Accord V6 Black
A few Mods
DV8 is offline
Old 04-22-2005, 06:43 PM   #14 (permalink)
Car: 95 Honda Accord ex
Vtec lude220 is an unknown quantity at this point
I also have the AEM SRI and I like it alot. I like the sound of it also. I don't know about the hissing sound but mine makes a loud humming sound when the car is warmed up. :clap
1995 Accord ex
96-97 Front end
Aem short ram intake
Magnaflow muffler w/ 2.25 piping
DC sports shortshifter
Eibach sportlines
KYB AGX shocks
pics of my car!!!!
Its not just any Honda Accord ex, its a clean ass black accord
Vtec lude220 is offline
Old 04-26-2005, 03:44 PM   #15 (permalink)
bonestockls is an unknown quantity at this point
got it on my 95 ls
better pick up
nice throaty sound
hissing at idle
good hp for the price
bonestockls is offline
