Just installed the Skunk2 I/M with Hondata gasket on my B18B with the help of a shop.
The install:
Everything bolted up fine, but needed longer studs, had some on hand in the shop, so that was fine. Needed to weld shut a couple un-needed holes, and needed some longer connections here and there...the throttle body cable I think needed fabrication. All in all, could do it for a 4 hour labour charge if you just gave it to a shop. Took us a leisurely 4.
Results:
With my mods in my sig from before, the sound changed a bit to a more raw all motor sound. It screams performance. Before it was a low deep gnarly growl, which I loved, but this is really cool too.
Not a TON of loss on the low end. You don't notice unless you try to give it some in 3rd gear right after a 'usual speed' 2nd gear shift. A bit sluggish until you get to at least 5k in 3rd. No change in 1st gear performance.
2nd Gear performance is verrrry noticeable. I got an instant smile on my face after 2nd gear passed 4,000 rpm. It blew me away how much the I/M helped. A very smooth transition into more power.
Also, the engine sounds MUCH happier when its close to redline. Before I was hesitant to take it to just before redline because of the sound she made. Now it sounds beautiful.
Summary:
Butt dyno.....way more noticeable power than a CAI, or a Header on their own.
The install:
Results:
Summary:
not a fan of that mani, but im happy for u, get u a real header on some nice profile cams and watch that "sluggishness" in third disappear...
Yea, I'm getting the stage 2 crowers this summer. People that have the Crower II cams without the mani get mid 150s for whp. I'm hoping for 160.
As for the DC-S Header, for my purposes, it's good enough. I've seen high horse and high dollar setups use the DC-S. The gains wouldn't really warrant getting another header.
Mods: built 2000 Integra Type R engine and tranny. Head is ported and polished, Crower rods, JE pistons Skunk2 stage 2 cams, REV Valves springs and retainers, skunk2 intake manifold, Act flywheel, RPS six puck sprung hub clutch, AEM cam gears, AEM fuel rail, STR cam seal, AEM V2 cold air intake, throttle body spacer, JDM ITR headers, APC catback exhaust
Originally Posted by NiceNloW
is there another I/M that skunk2 makes cause i got the Pro series on my z6. I didnt know they made another one.
I use to think the same thing cause I have Skunk2 IM and I've heard people talking bout the Pro series IM but can't fine it on their website but MY boy has one in his integra. The difference is the Pro series says that on top of it. I don't know if there is really any performance difference though.
Dam, did I just beat u in my Honda? Sure did, now your girl wants to get at me (True Story) "I built it, I drive it, your opinion doesnt matter. It doesn't have to be JDM it just has to be functional." http://www.texas-imports.com/forums/...referrerid=346
The install:
Results:
Summary:
lol how does a part make different amounts of power in different gears? feels sluggish in third untill 5K but faster in second at 4K and same in first?....i dont think so. it will perform the same in any gear as long as youre at the same rpm
lol I was a n00b when I did that write-up. However, the exact same power in every gear at the same RPM is only theoretical. Yes, power is all intertwined as a function of angular velocity (P=T*Rpm), and since angular velocity (RPMs) of the gears are related to the number of teeth on each gear (for example, (RPM of Gear 1 / RPM of Gear 2) = (# of teeth on Gear 2 / # of teeth on Gear 1)), there are losses found, and as such the same RPMs in each gear won't actually show the same power output.
Not taking anything away from you since these losses aren't noticeable unless you're on the dyno.
What I was feeling was merely the length of the gears. Not as much fun in 3rd, because I really gotta be breaking the speed limit to see the high RPMs.
And just to add to this review, this manifold REALLY helped my motor breathe with my cams. I saw 10whp more than most people see with these cams on a similar setup. I'd like to see the new Performer X on a setup like mine.
