Go Back   Honda Forum / Acura Forum - SuperHonda.com > Honda Racing > Part Review > Header
Old 04-10-2006, 07:22 PM   #1 (permalink)
festivagt's Avatar
Car: 94 Eg coupe.
AIRMASS(Holley) 4-2-1 Ceramic Coated Headers
Installed on my 94' Civic EX with a D16Z6 in it. Simple bolt on setup that is compatible with stock cats and aftermarket pieces. The finish was Nice even after the break in period for the ceramic. Stayed shiny and has a mirror like finish. Of course the O2 sensor had to be lengthened though so it could be put into the sensor socket at the back of the header. Came with all gaskets and bolts required - reused the stock header nuts/studs on the head. Definitely made a difference in the midrange on the car. Oh yeah - It's CARB approved(has a EO #).
festivagt is offline
Old 04-11-2006, 02:36 PM   #2 (permalink)
Car: 92 Civic 4Dr
Mods: CAI, Full TIEN coilovers, cat back, urathane bushings, msd coil, iridium plugs, ngk wires.
Printz has a spectacular aura aboutPrintz has a spectacular aura about
I have the same header and mine hasn't stayed shiny, it's been a month or two. Good product, only complaint is that at idle it vibrates against the block.
Never underestimate the bandwidth of a station wagon full of tapes, hurtling down the interstate.
The best forum ever, DIYs yo!!
D series lovers congregate here!!!!!!! :clap
4 Doors Rule
Street Legal Go-Cart
Printz is offline
Old 04-11-2006, 05:32 PM   #3 (permalink)
festivagt's Avatar
Car: 94 Eg coupe.
Do you have the stock header bracket installed? (the one on the back side of the motor that bolts near the intake bracket) If that one isn't installed you'll vibrate with ANY header you install.
Old 04-11-2006, 05:53 PM   #4 (permalink)
Car: 92 Civic 4Dr
Nope, there wasn't one there when i installed it.
4 Doors Rule
Printz is offline
Old 04-17-2006, 06:37 PM   #5 (permalink)
festivagt's Avatar
Car: 94 Eg coupe.
There should be one that comes off of the bracket the bottom of theintake bolts to and bolts to the flat bracket on the header at the back of the block.
Old 04-17-2006, 07:05 PM   #6 (permalink)
honda_racing101's Avatar
Car: 1994 Honda del Sol S/VTEC
Mods: Rocket motorzzzzzzzzzzzzzzzz.
honda_racing101 has a Rep problemhonda_racing101 has a Rep problemhonda_racing101 has a Rep problemhonda_racing101 has a Rep problemhonda_racing101 has a Rep problemhonda_racing101 has a Rep problemhonda_racing101 has a Rep problemhonda_racing101 has a Rep problemhonda_racing101 has a Rep problemhonda_racing101 has a Rep problemhonda_racing101 has a Rep problem
Well thatd be why its vibrating.
1995 Del Sol VTEC. Milano Red.
R.I.P.
1994 Del Sol S-full VTEC conversion.
http://www.superhonda.com/forum/showthread.php?t=319163
honda_racing101 is offline
Old 04-17-2006, 07:27 PM   #7 (permalink)
GunMetal Member
Car: 95 civic EX
NoRice4u2Day is a jewel in the roughNoRice4u2Day is a jewel in the roughNoRice4u2Day is a jewel in the rough
so you ahve to get the header tapped for the o2 sensor?
Originally Posted by 98Vtec
bewbie tassles
SHO Ninja Alliance
95 Civic EX
Soon to be R6
NoRice4u2Day is offline
Old 04-18-2006, 10:01 AM   #8 (permalink)
Car: 92 Civic 4Dr
No the bung was already installed. The bracket that was supposed to be on the back of the block wasn't there.
4 Doors Rule
Printz is offline
Old 07-30-2006, 06:48 PM   #9 (permalink)
Car: 94 Del Sol SI
Mods: b18c1 - skunk2 im - skunk2 ecu - xtd stage 3 clutch & 8lbs flywheel - msd ignition - ngk iridium spark plug & 8.5mm wires
xX94delsolsiXx is on a distinguished road
does AIRMASS header for Type R fit for GSR?
www.asiantuner.net
xX94delsolsiXx is offline
Old 08-28-2006, 10:27 PM   #10 (permalink)
Car: 1999 Accord V6 Coupe
Mods: K&N SR Intake, Unorthodox Pullies, OBX Headers, Comptech Exhaust, Vitek Plug Wires, Denso Iridium IK16's, Eibach Sportlines, Eibach Pro-Control Bar, CL-S Rear Sway Bar, 17" ICW Silver Rims, Grillcraft Upper & Lower Grills, etc.
AjIsDope is an unknown quantity at this point
It should fit.
I also picked up one of these headers for my b18b swap. Inexpensive and CARB legal.
90 HF
B18B N/A for now
AjIsDope is offline
Old 09-03-2006, 01:35 PM   #11 (permalink)
Car: 94 Del Sol SI
wat's the different between 4-2-1 and 4-1? which one do you guys suguest i go for?
www.asiantuner.net
Old 09-03-2006, 02:30 PM   #12 (permalink)
spyder06's Avatar
Car: BB2
Mods: never enough
spyder06 In the rep tropospherespyder06 In the rep tropospherespyder06 In the rep tropospherespyder06 In the rep tropospherespyder06 In the rep tropospherespyder06 In the rep tropospherespyder06 In the rep tropospherespyder06 In the rep tropospherespyder06 In the rep tropospherespyder06 In the rep tropospherespyder06 In the rep troposphere
a 4-2-1 header is one that has 4 primaries(i think thats what there called) that merge into 2 and those 2 merge into 1. a 4-1 header once again has 4 primaries only they just merge into 1. basically, a 4-1 is good for top end power and the 4-2-1 is good for mid range power.
92 Prelude Si
Engine/Power - H22A, short ram with BPi stack/K&N, Professional Products 68mm throttle body, Euro R intake manifold, Hondata gasket, OBX header, Tanabe Racing Medalion exhaust, NGK Iridium plugs, Vision plug wires/cap, MSD coil, Carbing catch can
Tranny - M2B4, Centerforce stage 3 clutch, unknown light weight flywheel, shortshifter
Suspension - KYB AGX struts, Tanabe springs, Megan Racing front/rear strut bars and rear tie bar
Brakes - unknown slotted/cross-drilled rotors, Axxis pads, red calipers
Now to put on the RS*R header and a 3" exhaust.
spyder06 is offline
Old 01-29-2007, 10:50 AM   #13 (permalink)
Spanman702 is an unknown quantity at this point
Hey help me out here
i was about to buy those off Ebay from a company in Jamestown, i live in erie. It was all good and they looked pretty good, (CARB approved!) but they dont come with the header extension! How di you lenghten it? did it work well? can you just buy a lengthened cord like the ones that you get with the pacesetter headers?
Spanman702 is offline
