07-31-2004, 08:20 AM
#1 (permalink)
Super Moderator
Car: 01 MR-St & 08 M3
AEM Brake Pads
holy wow! these things BITE HARD!!! i had them on my accord and they out-performed the OEM pads in every way. less distance to stop and decreased brake fade. i think they retail pretty though...i forgot what they normally go for, but i only bought them because i needed new pads, and since i worked for a garage, i was able to get them for cheaper than what autozone sells their pads for
Natural Progression...
Nulla tenaci invia est via.
For the tenacious, no road is impassable. Team SHO: 54075 - Folding for a cure
folding@home
08-12-2004, 07:52 PM
#2 (permalink)
GunMetal Member
Car: 1996 Integra LS
Mods: Eibach Pro Kit, Koni Yellow shocks, Neuspeed short shifter, Neuspeed front strut brace, DC header, Iceman intake
So these are great pads? I bought some and gonna install them along with my power slots this weekend. Can you believe I'm replacing ORIGINAL pads on my 1996 with 90k miles? And I still have 20% pad left the dealer said. Crazy.
"My car's not slow, it just has a low metabolism."
1996 LS|Iceman CAI|DC 421|Evo|Neuspeed Sport springs|Koni Yellows|Neuspeed front brace|Neuspeed short shifter|AEM Pads|Duralast rotors|14" Stocks with Kumho Cheapies
08-12-2004, 08:22 PM
#3 (permalink)
Car: 01 NBP Integra GSR
For a lil FYI
OEM's are made by Nissin, the same manufacture of the AEM pads.
08-12-2004, 08:32 PM
#4 (permalink)
Originally Posted by martinez32
For a lil FYI
are you trying to say thier the same
08-12-2004, 08:34 PM
#5 (permalink)
Super Moderator
For a lil FYI
which means the fit will be perfect....but the pad material is a different from the oem pad, so it bites harder.
folding@home
08-12-2004, 08:58 PM
#6 (permalink)
GunMetal Member
Exactly what I was about to say. manufactured by OEM peeps, but with a more aggressive compound. OEM fit, aftermarket performance
08-13-2004, 06:37 PM
#7 (permalink)
Car: 00 CDM civic Si
I just changed both my rotors now Brembo cross drilled and Aem/Nissin pads. I've only driven the car round town and am happy with he setup. I'll let u know after some more spirited driving
00' CDM  Si with some parts
I wish I had a track in my backyard
The Search function sux on this site
08-31-2004, 06:54 PM
#8 (permalink)
Car: 00 Civic Coupe & 96 Civic Hatch
Mods: Nothing in there but the hamsters.
I picked up a set of them with some cross drilled & slotted rotors. Can't wait to give them a try.
Zero - 00 VSM EX Coupe
Password CF Intake
Carsound CAT
Function Form Coilovers
ST Sways front and rear
99-00 Si Rims
Epyon - 96 VSM DX Hatch
AEM Intake
BBR D16Y8 Head and tranny
DC Sports 4-1 Header
Rear disc conversion
D2 Coilovers
Hella 3rd Gear VTEC y0!
08-31-2004, 08:02 PM
#9 (permalink)
GunMetal Member
Hey just an update to my brake setup. After a couple weeks of "braking" in they seem to make the car stop a lot better. Before they broke in and rubbed all the paint off the rotor surface, they were kinda disappointing to me. But now after I put some miles on them and did the heat tempering process, they work wonderful. Most noticeably when braking hard. Under normal braking, they work approximatly like stock brakes. But when you brake hard, they perform where stock brakes fail. There seems to be NO fade under hard braking and actually stop the car MUCH faster when a little more pressure is applied. So all in all, great setup so far! And looks kick @$$!!
09-01-2004, 06:13 PM
#10 (permalink)
I have noticed the same thing. I find myslef braking to early somtimes goin into a corner. They make me feel very confident both in spirited driving and when i don't think I can make a light
09-01-2004, 08:54 PM
#11 (permalink)
Car: 05 PSM WRX Wagon, 07 335i
Mods: bimmer:vishnu stg1 wagon:built 2.5l, GT35R, dogbox, and a bunch of other toys.
For a lil FYI
Yepper. I've had AEM and Nissan sitting side by side and they are identical except for the color of the backing plate. The compound looked identical even under a magnifying glass.
These are MUCH better than stock. Less dusting, when they do dust it's a dark gray so it doesn't look horrid, never ever squeeked, almost NO fade even under the harshest abuse, and even when they were bordering fade they still had a firm pedal feel unlike the sponges also known as stock pads. The bite is great, you'd almost swear you went to a bigger rotor.
I've tried Axxis MM on the accord and they had a great bite both cold and warm, but they were noisey as all hell(sounded like they were ripping the rotors to shreds, because they were) and they squeeked bad when cold. They dusted Sooooo much because of their bite. If you need to stop and don't care about only getting 1 turn(milling the rotor one time) out of a rotor then these are for you.
I've tried raybestos quietstop ceramic pads and these were the first brakes EVER that I removed before I needed to. I tried to tolerate them for about 2 months but they were soooooo unsafe it wasn't even funny. yeah they were quiet, yeah they were very very low dusting, but they forgot one key point, they didn't stop, and if you tried to slow from 45 to 0 two consecutive times they faded, and I mean went to 0 stopping power. And I'm not talking put my foot through the floor stopping, I'm talking mild commuter traffic 45 to 0 stopping. I almost went up someones ass so I changed them immediately.
I've tried EBC green stuff pads and they were the inverse of the raybestos for the most part. The did have low dusting but they were noisy as hell. They sucked when cold, but once you got the suckers warmed up OMFG did those things bite. For as much bite as they had I was surprised they were relatively nice to the rotors.
Out of all of the pads I think nissin(not nissan) pads are the best bang for the buck and the best of all worlds. Relatively low dusting, pretty quiet, good bite, good cold stopping, good hot stopping, little fade, great pedal feel, all around great pad.
I'm currently running Carbotech Bobcat pads with perrin 4 pot calipers up front and steel braided lines on the subbie and there were NO pads on the accord that even came remotely close to the stopping power of this setup, I can't imagine what a big brake setup would be like.
07 335i Quick
05 WRX Quicker
*as a side note: people with >1MB sigs blow me*
09-02-2004, 07:47 AM
#12 (permalink)
Nice Sig I have heard good things about carbotech too bad no one in canada sells em.
09-02-2004, 05:38 PM
#13 (permalink)
Originally Posted by CanSi2G
Nice Sig
Thanks  It was fun doing it, but it took me almost 8 hours of detailing to get the sand out of everything. Note to self: before driving like a maniac in the sand, ROLL UP THE WINDOWS. The first dump of the clutch I had all four windows down and was sneezing sand for the next two days
07 335i Quick
05 WRX Quicker
09-03-2004, 09:52 AM
#14 (permalink)
Super Moderator
sweet thanks for the review of all those brands
oh and rip to your car and congrats on the new one
btw, check out scca's site and see if they have any rally-cross events near your place. looks like you could have fun running at those
folding@home
09-09-2004, 06:44 PM
#15 ( | |
