When manufacturing a sophisticated suspension system there are many aspects that need to be considered to achieve extraordinary results. After exhausting efforts we feel that we have produced the ultimate coilover system.
We not only wanted a system that performed well on the track but also could be driven on the street. This is not as easy as it may seem, however we feel that we have achieved the perfect combination! Using many of the technologies found in Porsche 911 GT2/GT3 coilovers, we carefully configured bump and rebound settings for each specific application to produce optimum driving dynamics
We used spring rate of Sports (F=12K & R=10K) and Street (F=10k & R=8K) damper rates that yield exceptional handling characteristics coupled with unsurpassed street drivability
Our coilovers can be raised or lowered, up to 4”, from two separate positions which allows the user to raise or lower their vehicle without affecting spring preload or damper stroke length. We incorporated large 46mm pistons along with 20mm shafts which we found far superior to typical smaller piston/shaft coilovers. By using large 46mm pistons we were able to greatly reduce the stroke length, while still moving the same amount of fluid, resulting in unprecedented efficiency. All coilover systems include high grade aluminum pillow mounts further enhancing overall control. We used CNC Wound SAE 9254 Racing Springs which were found to be the longest lasting spring on the market that showed no tendencies to sag.
So whether you are looking for a great track set up or you need a suspension that adapts to public roads, you have found the right coilover. Omni-Power, Designed and manufactured for customers who demand the very best!
All Orders Come With:
- 46 mm Piston Size, Resulting In Superb Overall Control.
- 20 mm Shaft Designed To Withstand Both Track Abuse As Well As Road Imperfections.
- CNC Wound SAE 9254 Super High Quality Springs.
- 2 Front & 2 Rear Full Coilovers
- 4 Anodized Pillow Mounts
- Lowering Wrenches
Extensive Research And Development Went In To Choosing Precisely Matched Spring & Damper Rates Specific To Each Application. The Result Is Outstanding Ride Quality & Incredible Handling Characteristics!
Available for:
Honda Civic EX, LX, DX, Si HB 1992-95
Honda Civic DX HB, CX HB, EX, LX, HX, DX 1996-00
Honda Civic SI DOHC Vtec 1999-00
Honda Civic Si EP3 2002+
Honda Civic EP 2001+
Honda Accord 90-97
Honda Accord 98-02
Acura Integra GSR, LS, LS Special, RS 1994-01
Acura Integra Type R (Street Version) 1994-01
Acura Integra Type R (Sport Version) 1994-01
Subarua WRX
Mitsubishi Lancer Evo VIII
Acura RSX Type S 2002+
