I know this question should probably go to the non tech forums but i chose to ask it here because more people in a shorter amount of time would respond . Recently my shitty ass Nankang tires took a dump on me and tore up. They are not worn out, they just tore up. So i took my rims of and put my steelies back on, took my front lip and side skirts of so i wouldn’t scratch because the car is obviously lower then it was with the 18's on. It looks like shit! I need to buy tires as soon as possible. My question is will 225/35/18 tires fit a 18x7 rim. What i currently have on is 215/35/18. I checked some sites and it said that 225 would only fit 7.5 and up. I called a shop near by and they told me that it would fit. I would like for my tires to be a little wider so thats why i'm asking. Thanks for understanding
"F*ck fast and the furious, I ride slow 'n' luxurious"
Bigger, Badder, and Better
Cautela: First of all when trying to sound smart make sure you don't mix words which meaning conflicts with each other, for example "flawed" and "analysis" should not be used toghether because there isn't such a thing as a flawed analysis since an analysis can only be right or wrong ...confusing isn't it?
