B16 nitrous tune
O K ,
So I took the ZEX wet nitrous kit off of my Teg racecar and want to put it on my CRX B16.I remember backing the timing off 4 degrees and running a 2 stage colder plug.How will the car preform under DD with these settings if I only want to squeeze occasionally.What do I need to add to adjust back and forth.I found on the Teg that no kit is plug and play,and had I done that with the teg and not got on a dyno I surely would have detonated that thing in short order.With the smallest N2O jet and the biggest fuel jet,I was still way too lean(14.0/1.0).Any thoughts guys.
