Originally Posted by smrx8
You might be able to extract a bit more out of it..it depends completely on your setup and where the nozzle is mo0unted, how much you're spraying..because each nozzle pattern is different and the atomization is different..there are some that are better suited towards sport compacts and others towards larger motors with larger intakes..Personally I'd stick with NX or NOS products..the craftsmanship is nicer and they have been tested thuroughly...that part you linked doesnt look liek anyone took any time with it..you can still see the burrs on the edges of the holes
