» Sponsors
» Sponsors
Old 01-16-2003, 12:51 AM   #1 (permalink)
Car: '99 ex coupe
Mods: Bone Stock
oxygencube is an unknown quantity at this point
Building my d16y8 for 65+ shot of n2o
I am looking for some minor - medium boost... either n2o or supercharging ...I am thinking of doing some building work so I could run a higher shot I would like oppnions the +'s and -'s of these options .... thanks
Enjoy life.
oxygencube is offline
Old 01-16-2003, 03:58 PM   #2 (permalink)
Car: 98ex
Mods: motor/tranny out
Toddnos is an unknown quantity at this point
Re: Building my d16y8 for 65+ shot of n2o
Get some rods from a d16a1 88-91 teg.
they can handle up to 220 hp. A set of eagle pistons should
be able to handle anything you throw at it. But without proper fuel tuning you will still burn shit up.
TPP
Toddnos is offline
Old 01-18-2003, 10:06 PM   #3 (permalink)
Car: '99 ex coupe
Mods: Bone Stock
would I need both of these??? and if this is all I get as far as internels go what would I be able to spray? was thinking of 75 dry shot or direct port??? thanks
Enjoy life.
Old 01-19-2003, 06:12 PM   #4 (permalink)
Car: 00 Civic Coupe -Stoled- & 96 Civic Hatch & 03 S2000
Mods: Nothing in there but the hamsters.
-=Zeqs=- has a Rep problem-=Zeqs=- has a Rep problem-=Zeqs=- has a Rep problem-=Zeqs=- has a Rep problem-=Zeqs=- has a Rep problem-=Zeqs=- has a Rep problem-=Zeqs=- has a Rep problem-=Zeqs=- has a Rep problem-=Zeqs=- has a Rep problem-=Zeqs=- has a Rep problem-=Zeqs=- has a Rep problem
A D16Y8 can handle 75 shots of nitrous no problem. The things you need to do, are the same things you would need to do even if you had a built engine.
Spark plugs that are 2 steps colder, gapped tighter.
Retard ignition timing by 2-4 degrees.
Upgrade your fuel pump.
Use ATLEAST 91 octane fuel.
-=Zeqs=- is offline
Old 01-20-2003, 02:16 AM   #5 (permalink)
YayAreaBoy is an unknown quantity at this point
75 shot on a STOCK D16 might be pushing it a little even if you had all that ignition stuff...you could probably run 75 shot every once in awhile but not alot espically on you motor...also your gonna need a stronger clutch
YayAreaBoy is offline
Old 01-20-2003, 04:17 AM   #6 (permalink)
Shit, you're right, forgot about the clutch. That will be a must after a few times.
75 shots though, on a dry kit isn't shit. Did that for well over 6 months. Went through probably...250 lbs of nitrous? Two ten pound bottles...both refilled each week, six months.
Don't try to go daily with more than 60 shots of a wet kit though.
I don't advise doing that though, it's more cost effective to go turbo at that point. 250 * $4 = 1,000 Just in fills over a course of six months.
-=Zeqs=- is offline
Old 01-23-2003, 02:26 AM   #7 (permalink)
Car: '99 ex coupe
Mods: Bone Stock
ok I gotta retard my timming... that means a Cam gear right??? I hear AEM is the best... true?? also would a Cam be a good Idea if I am getting a gear for it?
Enjoy life.
Old 01-23-2003, 08:42 AM   #8 (permalink)
AcidLotus's Avatar
AcidLotus Why haven't you checked into rep rehab yet?AcidLotus Why haven't you checked into rep rehab yet?AcidLotus Why haven't you checked into rep rehab yet?AcidLotus Why haven't you checked into rep rehab yet?AcidLotus Why haven't you checked into rep rehab yet?AcidLotus Why haven't you checked into rep rehab yet?AcidLotus Why haven't you checked into rep rehab yet?AcidLotus Why haven't you checked into rep rehab yet?AcidLotus Why haven't you checked into rep rehab yet?AcidLotus Why haven't you checked into rep rehab yet?AcidLotus Why haven't you checked into rep rehab yet?
You don't necessarily need a cam or a cam gear. You can retard the timing at the distributor... should be three bolts you loosen, then rotate the whole distributor assembly clockwise, that will retard your timing. A cam might adjust the values of overlap and duration, and may be beneficial in a nitrous setup, but don't get a cam gear unless you have a cam (you don't need it since you'll either advance or retard the timing by 10* with every notch on the cam gear, and you'll sacrifice low end torque for high end HP or if you retard it, you'll sacrifice high end HP for low end torque. Just leave it at 0 just like the stock cam is set at).
2005 TSX 6MT + Navi
AcidLotus is offline
Old 01-23-2003, 01:57 PM   #9 (permalink)
pillypimpinit is an unknown quantity at this point
i think you heard wrong... aem gears only have three bolts.. your gonna want more than that... try gettin a skunk2, toda, or jun cam gear.. ive heard good things
pillypimpinit is offline
Old 01-27-2003, 11:34 PM   #10 (permalink)
Dont fuck around with you CAM GEARS to retard timing get an IGNITION to mess with you timing...get an aftermarket ignition..(MSD, Crane, etc)
...if you want to get rods that are stronger and cheaper get some B18B or B16 rods....B-series rods in a D-series block YES they will work with a little customization done to them and there WAYYYY stronger than those tooth-pick d-series rods
