if the bottle pressure was really low then you won't feel much of anything, especially with a 35 shot. if you're running a wet kit (which you're prolly not) and using low bottle pressure, the system will be injecting too much fuel compared to the amount of N2O. a bottle heater and gauge is a good idea. also checking your plugs, like you said you were gonna do, is a good idea. that can tell you what your mixture is like.
i'm sure the motor is fine though. just take a look at the plugs.
BTW what Z28 said is true. i ran 100-125 shot on my motor last year and when i installed the 75 shot jets to try them out, they felt really slow but were working correctly. and after you get used to the higher injections, even they feel slow. but the bottle pressure makes a lot of difference.
