» Sponsors
» Sponsors
Old 01-26-2003, 10:35 PM   #1 (permalink)
Car: 91 Integra
Mods: Intake, Cat-back, short shifter, advanced timing
humpy012 is an unknown quantity at this point
good compression numbers?
I was told to check compression, so i did:
1 200
2 190
3 180
4 175
are these good enough for a 50 shot on my ls of 160k miles?
I'm looking for a set of aftermarket hupcaps.
humpy012 is offline
Old 01-27-2003, 02:05 AM   #2 (permalink)
Iron Monk
bonestock94 has much to be proud ofbonestock94 has much to be proud ofbonestock94 has much to be proud ofbonestock94 has much to be proud ofbonestock94 has much to be proud ofbonestock94 has much to be proud ofbonestock94 has much to be proud ofbonestock94 has much to be proud of
all 4 of your clyinder compression #'s should be within 10-15% of each other. try running your car through with some seafoam or something of that nature and see if you can clean out some the the blowby/carbon deposits that might be causing your cyclinders to have such different readings.
my f22b1 read like around 175 all across i think
bonestock94 is offline
Old 01-27-2003, 11:58 AM   #3 (permalink)
Car: 91 Integra
seafoam???? is that a gas additive or something?
humpy012 is offline
Old 01-27-2003, 03:10 PM   #4 (permalink)
Iron Monk
kinda of like a carb. choke cleaner but for EFI cars.
i have a friend that uses 99% alcohol and cleans it with that via spraying it into intake manifold. my first compression reading was simular to yours but not off by as much as yours and my friend ran my car thru with some seafoam and i read almost 175 all the way across.
Old 01-28-2003, 01:50 PM   #5 (permalink)
Car: 91 Integra
should i disconnect the intake piping and spray it in while the car is running?
humpy012 is offline
Old 01-28-2003, 07:25 PM   #6 (permalink)
Iron Monk
how to on a z28, but its the same idea.
http://w3.one.net/~roz/cars/z28/seafoam.html
you can do either way using the brake booster vacuum or spraying into the throttle body.
