Originally posted by sweet
hey nice new pic of the Stang, fiveoboy!
the other pic was nice but a bit too large.
anything new on the setup for '03?
Thanks, I agree the other one was too big, that's why I switched.
Anything new? You HAD to light the fuse didn't you? Here goes:
R-302 based 311(FYI that's their bulletproof 4-bolt main block)
Eagle 4340 crank, counterweights knife-edged and cut(way) down
Eagle 4340 H-beam rods
JE custom nitrous pistons, light wristpins, Severe-duty nitrous rings
Real-street spec camshaft custom ground by Comp cams
ATI super dampener
Fidanza aluminum flywheel
Spec Stage 5 clutch
Tremec TKO2, pro-shifted, 5th gear removed
Strange driveshaft
Strange Pro-race 33-spline axles, Pro-race spool, 9" housing ends, big titanium wheel studs
New wheels and tires on all 4 corners
Strange aluminum disc brakes on all 4 corners
QA1 tubular K-member
QA1 coil-over struts in front
QA1 shocks in the rear, new FRPP C-springs in the rear
New custom rear upper/lower control arms
CE bumpsteer kit
My heads are at Total Engine Airflow in B.G. KY getting a full comp. valve job and freshening, new springs, guide seals, etc.
TFS Track heat intake
C&L 80mm mass air meter
42# injectors
5-gal RCI aluminum fuel cell
Magnaflow Pro-star EFI fuel pump
New fuel lines throughout(-10 feed, -8 to the rails, -6 return)
Aeromotive regulator
Aeromotive fuel rails
Manual brake conversion with Strange manual cylinder
Ford Racing EPEC engine management system
HP Motorsport H/D motor mounts, Energy susp. Trans mount
Corbeau Drag seat
ALL systems(ignigion, fuel pump, purge, fan, bottle heater) are being re-wired the RIGHT way with relays and wiring kits/switch panels from Painless Wiring
Edelbrock Victor water pump
Be-Cool aluminum radiator
Aluminum firewall for the hatch
MSD Pro-billet distributor
MSD crank trigger
That is all the new stuff.
I will try to get a few pics up for you.
If it doesn't make about 625-650 HP @ the wheels, and run 9.95s-10.teens, I will be very pissed.
