i was wondering if i put bigger injectors n a fuel pressure regulator n drop the fuel pressure down n shoot a dry 75 shot would it be save... i have 440cc injectors on my stock LS right now its running pretty fine stays on n idles good i had to drop the pressure real low around 2-5psi... just wondering if when i shoot the 75 dry it will make a difference the bigger injectors...
i dont think you would have to run bigger injectors at all. just a 255fuel pump. colder spark plugs, retard your timing just a lil...thats what they did on my friends si and he ran a 75 wet shot for 2 years
Mods: swapped.. ummm everything.. turbo.. umm yeah its quick i guess..
i guess its for every 50 shot you take out .2 degrees so take out 3 and get colder plugs, then spray it and check your plugs see what they look like, then you'll be able to tell if your lean or rich. then take it from there good luck
