my car was slightly tapped on my integra right in the middle of my front bumper. It looks like the plastic was just pushed in. Is there any way to fix this or do i need a whole new bumper? I was thinking about heating the plastic and pushing it out and maybe some sort of special bondo , but then again its plastic and wouldnt it shrink and expand due to heat? Thanks
_______
Originally posted by bri94lst my car was slightly tapped on my integra right in the middle of my front bumper. It looks like the plastic was just pushed in. Is there any way to fix this or do i need a whole new bumper? I was thinking about heating the plastic and pushing it out and maybe some sort of special bondo , but then again its plastic and wouldnt it shrink and expand due to heat? Thanks
_______
I'm not familiar with the teg bumpers...but they have plastic on em? I thought it was pretty much all fiberglass. But bondo should be able to work for pretty much anything if you're able to clear the area up and get rid of that excess damaged crud and really prep the surface.
Originally posted by bri94lst someone told me the bondo wouldnt stick to the plastic bumper good enough? and that i might need some kinda special bondo? Anyoneknow about this?????
i dont think bondo will stick. ask your local body shop
Created by me, PM me if you would like one* Phases 1. Buy SR20DET2. Pull SR/Prep 3. Pull Ka 4. Drop SR in 5. Wire 6. Enjoy
Mods: Custom Turbo System, Haltech E6K, Custom Paint, Built Motor
There is a urethane fuller putty that should be used for plastic and urethane parts and bumpers. . . Bondo will probably not bond correctly nor will it be flexible like urethane, plus bondo and urethan have different thermal expansion rates, so you will ultimately end up with cracks. Repair urethane bumpers with urethane filler.
Originally posted by bri94lst so the urethane filler DEFINITELY wont crack???
there is no definite when it comes to body work... anything can crack...
|Truth is One|paradigm? Uplift your soul with some Drum n Bass. Click tracks below
|A.I. Uprising VIP|Q Project Ask Not|Calibre Mr Majestik|XRS A Mosca|
You extend your past into your present, creating a future like your past, and thus you never really experience the present. Living this way, you will never experience the perfection of the present moment.
They're right. Can't use Bondo. Urethane filler *can* crack.
How bad is it? Pics? Have you taken it to a body shop for an estimate?
Without seeing it or knowing how bad it is, you can either live with it, get it repaired/repainted, or replace it with a new factory/aftermarket bumper.
Just my $.02
If you don't know, say you don't know....
