Go Back   Honda Forum / Acura Forum - SuperHonda.com > Performance - Tech > Cosmetic & Body
Old 04-19-2005, 03:14 PM   #1 (permalink)
bloodyangel is an unknown quantity at this point
Installing Hood Pins
Ok, now I that I got the hood on my car, I'd like to get a set of Hood pins for the front of the hood. How should I got about installing these? I have to drill into my CF hood right? Any suggestions would be nice.
bloodyangel is offline
Old 04-19-2005, 04:37 PM   #2 (permalink)
Car: 95 4dr civic
Mods: Full VIS bodykit, VIS Carbon Fiber Invader hood, 99 GSR Dash and console, JDM Steering wheel, 2.5in Tenzai catback exhaust, TYC one peice projectors, Depo led tailights, 17" Gunmetal Evolution Rims wrapped in Toyo Proxes FZ4s, and not enough room
j95civic is an unknown quantity at this point
That would nice to know since the hood is at an angle, I have a VIS carbon Fiber hood, let us know?
j95civic is offline
Old 04-20-2005, 02:12 PM   #3 (permalink)
IISaiNtII's Avatar
ok, first things first.
find out where you want to locate them, and make sure there will be enough clearance & space for the pins, also, make sure that the location you use wont be too tall for the pins to work right (i nearly had this problem, but i am using hood locks, dont know if this will apply to hood pins or not) most people put them at the front of the car, on either side of the grille, seems to work out best that way.
second thing to do, find out how big of a hole you'll have to drill to accomodate the pins/locks. then get yourself a drill bit, a variable speed drill works best, but not 100% necessary if you can't get one. the bit i needed was 3/4 inch, which if you dont know, is f*cking huge, myself, my dad, nor my best friends dad (a master mechanic) had a drill with a large enough chuck to fit a regular 3/4 inch bit... so i used a paddle bit, which, wasn't what i would have liked to do, but it worked.
next, you'll want to line up your holes. i did this by using a red marker on the top of the lock part that resides under the hood. i put them in the location i chose, marked the very top with a lot of ink (paint or white-out may work as well) and lightly closed the hood. this took alot of tries because i didn't want to slam it shut and go through the top of the hood, so i had to raise the lock part in increments to get them to even touch the underside of the hood.
next, if you're satisfied with the location you chose, and have you drill and bit handy, go to work. if you chose a spot like i did, you will have to mark for the holes twice, which was the most tedious part, and a big P-I-T-A when your drill runs out of juice on ya. make sure you drill straight through the hood at the proper angle (to the best of your ability, i had no problem doing this on the car with the hood up), you should be able to tell what is relatively straight by eye-balling it.
thats really about it :byye
-Proverbs 16:31
- Martina Navratilova
IISaiNtII is offline
