...so my battery light came on and I had the battery and alternator tested at three different stores, all said the battery is fine - 12 + volts and the alternator is OK 14+ volts. They also said the voltage regulator is OK.
However, the battery light is on when I go above idle. BUT, when I load it up - AC, headlights, etc, the light GOES OFF while driving AND at idle.
What I have done:
Tested the battery and alternator at home with my rig and at three stores, all good.....
Charged battery to full charge.....
R&R battery posts and cleaned everything. Checked belt tension and it is tight.
Cussed and yelled....
I am guessing "Alternator" regardless but....I did take off the plug and it was not bad, I may wire brush it....
So, put in a new set of brushes, VR and Recitifier? Get a Reman?
Thanks Honda folks....
What I have done:
