I am having an issue with my '91 Accord 4 cylinder with automatic transmission. I started it up this morning to let it warm up and when I went out to get in the car the engine was revving up and down. I looked at the tachometer and it was starting at where it should be at idle then up to about 2 grand and then back down again.It kept doing this. Once I put it in drive it seemed to level out.
Once I started driving the car it seemed to lurch into first gear and then it would take a while for it to shift gears. I tested shifting the gears manually and it acted like it didn't want to shift into second and third. The automatic transmission has the sport mode button and when I turned that on the transmission seemed to shift a bit easier.
I am stumped as to what is going on here. Does anyone have any ideas on what the problem could be?
