As the title says, I have a strong vibration at idle.. It's got the 2.2 16v, and an auto trans.
The vibration seems to stick around to about 3000rpm, and then it smooths out. I have a feeling that its a bad motor mount. The mount by the fan seems to have quite a bit of play. The one by the driver side wheel well seems way tighter.
I know the car is in dyer need of a good tune up, what else could cause this vibration? If it is just the motor mounts, what do I have to take apart to change them?
Other questions:
What should I gap the plugs at?
The auto trans needs service. I was told I can use a standard dexron II or III, over the expensive Honda ATF. Would this cause any problems?
Where the heck is the filter for the trans????
Lastly I have been looking at this exhaust on ebay:
Accord F22 CB7 Stainless Catback Exhaust Muffler 4" Tip Header Cat Pipe Silencer | eBay
It looks ok, and I was told that the quality isn't that bad. I need to replace everything anyway cause my manifold is cracked.
I was just wondering if I should get a cold air kit as well, to complement the exhaust? If I do, what is a good one that doesn't cost to much?? I just don't want to add to much to this miled old motor, and have it blow up on me.
