92 Honda LX Electrical Issues
I have a 1992 Accord LX. My car currently has no power to the dome light, cigarette lighter, rear defroster and the power antenna does not work. I do have power to the radio. The power to these item died when I took the power adapter for my GPS out the cigarette lighter.
I did not find any blown fuses under the driver side dash panel.
Under the hood I did find a blown fuse to the #22 slot and the #29 slot. After replacing those two fuses there is still no power to the items that were failing previously. I also checked the back of the cigarette lighter to see if the solder melted from the the connecter inside the white plastic fuse but I am still having the same issue.
What should I test or look at now?
