A couple of months ago while driving check eng and D4 started blinking. Pulled over checked manual and D4 is trans code vss sensor,check eng code 17 vss Restarted car everything ok . Last week same problem occurred and i bought a vss . This part is in a hard to reach spot top of trans near firewall. Here are some tips.
-tools some type of light,3 long ratchet extensions, swivel,3/8 ratchet,1/4
ratchet with small extension,strong magnet with long handle to reach bolt
closest to eng .
-remove throttle / air cleaner hose and all vacuum hoses attached to it.
-remove 2 bolts from vss the one bolt near eng break loose until loose and
use magnet to remove and pull up.
My hands are small and there is not ample working room install vss with pin installed.
-start bolt near firewall leave loose, align housing and bolt hole on other side
- use magnet with bolt on end lower to vss and turn a couple times to get
started. Use 1/4 ratchet to tighten there should be enough room followed by 3/8 to finish.
Hope this helps
closest to eng .
Hope this helps
