have a 94 manual, 4 cyl Accord XL, 250K miles
My engine suddenly died and won't start, emergency flashers don't come on. Horn, radio don't work.
Now, even with the key removed from the ignition, when I step on the brake, the oil light and the alternator light go on and the wipers move a little. Same when I try the headlight switch, the window switches, or when the dome light is supposed to go on from opening the doors. Also, when I turn the key to start, nothing happens while I have the clutch depressed, but when I take my foot OFF the clutch, the engine turns over (doesn't catch) opposite of normal function.
Disconnected the battery for a few minutes but still the same after reconnection. Oddly, there was no sparking when I removed cable from positive post and when I reconnected, yet the battery has enough juice to crank the starter as normal.
Anybody ever run into this? What in the world is going on?
