I have a '91 Accord. The other day the blower motor for the AC/Heater stopped working. I looked under the hood and found that a fuse for the blower was shorted out so I replaced the 30 amp fuse. That didn't fix the issue. What else should I look at?
Has the fuse blown again? If not, then you might want to take a look at loose connections, burnt or short circuited wiring looms and stuff. Also consider inspecting the blower assembly, since the solenoid may also have worn out. Another area which can be covered is the switches. Check for proper functioning and replace if necessary.
cb7tuner.com has an excellent diy about electrical gremlins
Related Threads
Honda and Acura Car Forums
4.2M posts
169.9K members
Since 2002
