Mods: Nuespeed Sports, Tokico Illumina, Konig Appeal, AEM CAI, DC Sport short shifter, Invidia Catback, 8K HID conversion, Carbon Fiber tail
BUNK!
I'm not sure what it is but
I just recently installed an Exedy CLutch combo, Prostreet 11.5LBS flywheel
on a 6th Gen Accord. When i depress the clutch I can hear a BUNK! on coming from the tranny, has anyone came across this problem?
__________________ Thou who does not get licked first, will not get licked!
sounds like you didnt install something correctly. did you torque everything down to spec? also did you replace the throw out bearing? is the fork aligned properly?
__________________ Need GOOD Performance Parts? - send me a PM for a quote.
can you record the sound and post it in the forum so we can hear it. Describing a sound and hearing a sound are 2 different things. where did you get the clutch combo from?
A job done right ='s peace of mind.
I'll try my best to record the sound the best i can considering there will be engine noise in the recording.
My front engine mount was bad and i replaced it a month ago.
Got the clutch flywheel combo kit from prostreetonline
usually that sound comes from the rear mount being bad. when the engine torques up, then you engage the clutch, there is no more torque on the engine and it falls backwards and goes BUNK. this happened to me when i went h22 on my accord. the rear mount failed and i had to go back there to replace it a few weeks later.
Do our our 6Gen Accords use a Pilot bearing? I don't recall seeing a OEM one when i did the upgrade. and so i didn't install it, could this be a factor of the BUNK?
I'll check the rear mount, after i shovel some snow
