Dc headers on ULEV engine? - Honda Forum : Honda and Acura Car Forums
Old 02-22-2012, 06:21 PM   #1 (permalink)
Car: 98 Accord Ex coupe 4cyl f23a4
dunluvmeeh is an unknown quantity at this point
Ok I was excited that my new dc headers HHC5018 arrived today. I opened it and the instruction says "this header is not intended to be used on any ULEV engine"
That means in screwed?? Can't install the header?
Or is it fine to install it?
I have 98 accord 4 cyl. F23a4 engine
dunluvmeeh is offline
Old 02-22-2012, 09:40 PM   #2 (permalink)
nusdogg's Avatar
Car: 1994 Honda Accord Ex
Mods: 204whp/157wtq
nusdogg needs rep therapynusdogg needs rep therapynusdogg needs rep therapynusdogg needs rep therapynusdogg needs rep therapynusdogg needs rep therapynusdogg needs rep therapynusdogg needs rep therapynusdogg needs rep therapynusdogg needs rep therapynusdogg needs rep therapy
You can go ahead and try it to see why it won't work on the ULEV. Maybe they don't want you to run the header due to the low emission of this motor?
Originally Posted by JSA Motors View Post
The H22 wakes up the Accord in the same way a set of secondaries did to your father's Oldsmobile.
nusdogg is offline
Old 02-23-2012, 01:29 AM   #3 (permalink)
Darth Chinko
Darkness's Avatar
Car: 1993 eg hatch/1998 ls coupe
Mods: vtec, hp/liter, and a paul walker t-shirt
Darkness Bow down before me!Darkness Bow down before me!Darkness Bow down before me!Darkness Bow down before me!Darkness Bow down before me!Darkness Bow down before me!Darkness Bow down before me!Darkness Bow down before me!Darkness Bow down before me!Darkness Bow down before me!Darkness Bow down before me!
get tune so you don't run lean
"Nismo stands for Nissan Motorsports, Homo stands for Honda Motorsports"
-Kyle Basbous
contact: marques@b16suck.com
Darkness is offline
Old 02-23-2012, 08:48 AM   #4 (permalink)
What do you mean?
Old 02-23-2012, 09:15 AM   #5 (permalink)
legacyo13's Avatar
Car: '93 Del Sol Si
legacyo13 Why haven't you checked into rep rehab yet?legacyo13 Why haven't you checked into rep rehab yet?legacyo13 Why haven't you checked into rep rehab yet?legacyo13 Why haven't you checked into rep rehab yet?legacyo13 Why haven't you checked into rep rehab yet?legacyo13 Why haven't you checked into rep rehab yet?legacyo13 Why haven't you checked into rep rehab yet?legacyo13 Why haven't you checked into rep rehab yet?legacyo13 Why haven't you checked into rep rehab yet?legacyo13 Why haven't you checked into rep rehab yet?legacyo13 Why haven't you checked into rep rehab yet?
Shouldn't he be running lean anyways on a ULEV? I can see this being the reason why since the computer will lean him out even more.
Lean being gas.
Hit me up on Facebook.
legacyo13 is offline
Old 02-23-2012, 09:35 AM   #6 (permalink)
i will run more gas? how can i reduce on running gas?
Old 02-23-2012, 10:18 AM   #7 (permalink)
Darth Chinko
Darkness's Avatar
What?
-Kyle Basbous
Darkness is offline
Old 02-23-2012, 10:29 AM   #8 (permalink)
You said "get tune so you don't run lean"
What does that mean?
Old 02-23-2012, 10:45 AM   #9 (permalink)
legacyo13's Avatar
Car: '93 Del Sol Si
Your computer runs the air/fuel mixture. The ULEV motors run lean, so it is pumping less gas into the motor, it allows cleaner emissions while saving on gas. When you increase the flow rate of the exhaust, the computer responds by running leaner, so you'll be running even less gas. Which could be harmful to the engine. So if you want to run the header, you will most likely need a tune to run the proper air/fuel ratio. You can probably pick up an A/F controller to handle this instead of a chip and tune.
Old 02-23-2012, 12:58 PM   #10 (permalink)
ok. i found some AEM air/fuel controller for around $180. are there any other brand out there? maybe cheaper
Old 02-23-2012, 04:16 PM   #11 (permalink)
Darth Chinko
Darkness's Avatar
you need a wideband
-Kyle Basbous
Darkness is offline
Old 02-24-2012, 07:25 AM   #12 (permalink)
SH Virus
fartbomber's Avatar
Car: Mazda Protege5
Mods: Magnaflow secondary catalytic converter
fartbomber you're still here?fartbomber you're still here?fartbomber you're still here?fartbomber you're still here?fartbomber you're still here?fartbomber you're still here?fartbomber you're still here?fartbomber you're still here?fartbomber you're still here?fartbomber you're still here?fartbomber you're still here?
It's not intended but that doesn't mean it can't. Fitment will be correct.
Other than the fact that you are going to get around 3-5 HP more power if that, you can install it and see what happens. Hopefully, there are oxygen sensors, a.k.a. O2 sensor, bungs (opening to screw a sensor into) in the header in similar locations as your OEM exhaust manifold and downpipe. If not, you will need to bring your header to an exhaust/muffler store and they can weld in the bungs for you.
Don't install a Vortec Cyclone (Tornado Air) air-intake funnel into your intake, you're going to hit 5,000 HP and that's going to hurt your header.
fartbomber is offline
Old 02-26-2012, 11:06 AM   #13 (permalink)
so I put the dc header on, it did come with an o2 sensor bung. but after 1 day my check engine light came on and it was a P1164 code which is bad primary o2 sensor? correct me if im wrong. I cleared the code and CEL hasn't come back on yet.
does that code says for sure that its a bad o2 sensor? or could it be because im running lean after the dc header was installed as you guys stated above?
also, can a bad cat. converter gives me that code as well? the reason im asking this is because I know my cat. converter is bad. its broken inside. I saw like a cube that got loose in the cat converter while putting on my header. its like a rock inside a coke can, when you shake it makes a rattle noise.
also, I replaced a new primary o2 sensor about 2 years ago.
Old 02-26-2012, 07:15 PM   #14 (permalink)
Darth Chinko
Darkness's Avatar
it's the header setting off the code with your sensor
-Kyle Basbous
Darkness is offline
Old 02-27-2012, 10:08 PM   #15 (permalink)
nusdogg's Avatar
Mods: 204whp/157wtq
^x2.
Obviously it's the new header that sets it off, assuming very thing was fine before.
nusdogg is offline
