Hi All,
Im having trouble with my stock fuel regulator. Im hitting 80-85 psi on idle and i don't have fuel flow. I tried to do the "drilling the fuel regulator trick" but still the pressure is 80 and the side effect is the rail doesn't hold pressure when you turn off the car, i also tried using a fuel regulator from an f20 SOHC but still the my pressure stays at 80 psi. Anyone have the same experience? what solutions can i do to fix this?
TIA
TIA
