HELP!!! clutch pedal not working - Honda Forum : Honda and Acura Car Forums
Wheel & Tire Center
Old 05-19-2006, 12:59 PM   #1 (permalink)
Car: 1995
Mods: Custom Exhaust, Headers, Intake, NGK plugs and Wire, HKS Grounding Kit, Glow Gauges
Accord_x is an unknown quantity at this point
Exclamation HELP!!! clutch pedal not working
so i installed everything and its all good. but the pedal dont work any more. u push it down and it stays down. try bledding it butnothing is happening. the bolt(where the the hydralic cable meets tranny) is all lined up. if u pump the clutch fork it works. but not the pedal. press on the pedal the clutch fluid come out but very slow. help
Accord_x is offline
Old 05-19-2006, 01:44 PM   #2 (permalink)
Car: 1994 Accord Ex
Mods: Greddy Header, XTD 12 lb Flywheel &Stage 1 Clutch, Tsudo Catback
sponginpunk has a spectacular aura aboutsponginpunk has a spectacular aura about
sounds mostly likely its ur master cylinder is bad...as long as you bleed it right
1994 EX Accord
Greddy SS Header
XTD 12lb Flywheel
XTD Stage 1 Clutch
Tsudo N1 Catback (soon to change the muffler)
Bomz SRI
sponginpunk is offline
Old 05-19-2006, 01:48 PM   #3 (permalink)
Iron Monk
bonestock94 has much to be proud ofbonestock94 has much to be proud ofbonestock94 has much to be proud ofbonestock94 has much to be proud ofbonestock94 has much to be proud ofbonestock94 has much to be proud ofbonestock94 has much to be proud ofbonestock94 has much to be proud of
are you leaking brake fluid anywhere?
when you bled it were there any bubbles in the fluid?
bonestock94 is offline
Old 05-20-2006, 09:28 AM   #4 (permalink)
Car: 1994 Accord
Mods: Custom Exhaust/Aftermarket muffler
Accord9400 is an unknown quantity at this point
Slave cylinder
I had the same problem, i think what you need is a new slave cylinder. It will probably run you around 100 bucks or so.
Accord9400 is offline
Old 05-28-2006, 06:30 PM   #5 (permalink)
Car: 94 accord dx/piece of shit
Mods: D16Z6 swap, cold air, headers,full exhaust, cam gear, msd ignition, nology wires, short shifter, strut bars, optima in the trunk, a.m. alt, 17s, adj coil overs, red tail lights, cross drilled rotors with painted calipers, red interior, sound system
kameone is an unknown quantity at this point
definitely the slave cylinder, I had the exact same problem right after a shop installed my clutch and new slave cylinder, I bought a new one for like $20 and installed it, it turned out that the shop did not bleed it properly.
kameone is offline
Old 05-28-2006, 07:19 PM   #6 (permalink)
tews19_1995LX is infamous around these parts
slave cylinder gaurantee it... get a new one or bleed the current one...
step one.... manually pump the pedal while someone is pouring in new brake fluid.
step 2...... keep this up until the pedal gets pressure ..once it gets back to normal have the other person close the valve on the slave cylinder ..only takes a matter of minutes
tews19_1995LX is offline
Old 05-29-2006, 08:03 AM   #7 (permalink)
Car: 1995
its all good now. i replaced both master and slave cylinder. i think i broke th eslave whiule i was pulling the tranny. out. but its all good now. only 300 more miles to break in the clutch n flywheel. 1000 miles. omg
Accord_x is offline
