Old 07-07-2008, 12:05 PM   #1 (permalink)
NCAD is on a distinguished road
How to check if fan is working?
I am reading on haynes manual where it says use "fused jumper wire" to connect fan directly to the battery.
What is "fused jumper wire"?
And how exactly do you connect it directly to the battery?
Thanks
'96 Accord DX. 115k.
NCAD is offline
Old 07-07-2008, 04:11 PM   #2 (permalink)
sc15's Avatar
Car: 1995 Honda Civic DX Turbo
Mods: T3/T4 Turbo, stage 3 clutch, h&r springs, skunk2 camber kit, fuel injectors, strut bars, short shifter
sc15 sc15 sc15 sc15 sc15 sc15 sc15 sc15 sc15 sc15 sc15
i did mine with speaker wire. i went from the fan, to the battery, to a switch.
sc15 is online now
Old 07-07-2008, 05:08 PM   #3 (permalink)
Car: 2004 WRX Stage 2
Mods: Custom Airbox, sway bars, Full Helix TBE and catless uppipe, Open Source tuned by yours truly, and many other goodies
cefiro80 In the rep tropospherecefiro80 In the rep tropospherecefiro80 In the rep tropospherecefiro80 In the rep tropospherecefiro80 In the rep tropospherecefiro80 In the rep tropospherecefiro80 In the rep tropospherecefiro80 In the rep tropospherecefiro80 In the rep tropospherecefiro80 In the rep tropospherecefiro80 In the rep troposphere
I did mine the same way
subaru right now but looking to join the honda family again....
cefiro80 is offline
Old 07-09-2008, 09:30 AM   #4 (permalink)
Super Moderator
UltraMagneticAL's Avatar
Car: 01 MR-St & 08 M3
UltraMagneticAL Why haven't you checked into rep rehab yet?UltraMagneticAL Why haven't you checked into rep rehab yet?UltraMagneticAL Why haven't you checked into rep rehab yet?UltraMagneticAL Why haven't you checked into rep rehab yet?UltraMagneticAL Why haven't you checked into rep rehab yet?UltraMagneticAL Why haven't you checked into rep rehab yet?UltraMagneticAL Why haven't you checked into rep rehab yet?UltraMagneticAL Why haven't you checked into rep rehab yet?UltraMagneticAL Why haven't you checked into rep rehab yet?UltraMagneticAL Why haven't you checked into rep rehab yet?UltraMagneticAL Why haven't you checked into rep rehab yet?
Thanks
a wire with a fuse in series with a switch. the wire should be rated for whatever the current draw is of the fan. speaker wire might be toooo small.
Natural Progression...
Nulla tenaci invia est via.
folding@home
UltraMagneticAL is online now
Old 07-09-2008, 04:13 PM   #5 (permalink)
thanks but where exactly can you get this "fused jumper wire"? walmart?
NCAD is offline
Old 07-09-2008, 04:25 PM   #6 (permalink)
Super Moderator
radio shack should have most of this stuff. you need a fuse holder, a fuse (the rating depends on the fan's current draw), and wire. you'll have to connect them together yourself. if you can solder, it would be much cleaner. but i think the fuse holders have screw terminals for pretty easy connections.
folding@home
Old 07-10-2008, 02:08 PM   #7 (permalink)
ok thank you. bear with with me please, i don't have the first clue about car electrics.
so i bought a wire says 18gauge, max 15 amps, max 180 watts. i don't know what it means but can i just attach them to "+" and "-" on the battery and connect it directly to the fan?
NCAD is offline
Old 07-10-2008, 03:05 PM   #8 (permalink)
Super Moderator
No. you will need to put a fuse for circuit protection and a switch to turn the fan on/off. i don't know what your fan is rated, but your wire and fuse should be rated no less than 125% of the continuous load drawn by the fan. actually, since it's going to be pretty hot in the engine bay, you'll need to get the next bigger conductor size. short circuits cause fires...and the proper protection can prevent that. i'm an electrical engineer, so i've seen my fair share of electrical fires.
folding@home
Old 07-10-2008, 03:29 PM   #9 (permalink)
so do i need 2 fuses and fuse holders for both - and +? and where do i attach the switch?
NCAD is offline
Old 07-10-2008, 03:57 PM   #10 (permalink)
Super Moderator
JUst one fuse
BATT (+) => FUSE => SWITCH => FAN => BATT(-)
folding@home
Old 07-10-2008, 05:59 PM   #11 (permalink)
i'll try that. thanks
NCAD is offline
Old 07-10-2008, 06:12 PM   #12 (permalink)
drummingpariah's Avatar
Car: 1973 Datsun 240z
Mods: Chevy v8.
drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?drummingpariah Why haven't you checked into rep rehab yet?
That'll definitely work. I'm in the process of rewiring my whole Datsun, from the ground up. It didn't have a fusebox in it before. If you're looking for an actual upgrade from the system you're using, go to an aviation/hobby store and get some aviation circuit breakers. They're essentially the same as fuses, but you don't have to replace them when they blow. I'm not entirely sure why auto manufacturers aren't using them yet.
Maybe because switches intimidate people?
Good luck.
drummingpariah is offline
Old 07-18-2008, 08:30 PM   #13 (permalink)
sc15's Avatar
k here's exactly how i did mine. i cut my cables for the fan. connected the speaker wire, you cut one strip of the wire. then one end goes to the negative, and the other end goes to the positive. do not cut the other strip. then they run to the switch. and walla. i didn't use a fuse since the cable is short and i dont see any chance of the cables touching and fucking anything up. it's up to you though. really.
sc15 is online now
Old 07-18-2008, 11:58 PM   #14 (permalink)
MortsAccord's Avatar
Car: 1997 Honda Accord EX
Mods: Header + full Catback, Intake.
MortsAccord Why haven't you checked into rep rehab yet?MortsAccord Why haven't you checked into rep rehab yet?MortsAccord Why haven't you checked into rep rehab yet?MortsAccord Why haven't you checked into rep rehab yet?MortsAccord Why haven't you checked into rep rehab yet?MortsAccord Why haven't you checked into rep rehab yet?MortsAccord Why haven't you checked into rep rehab yet?MortsAccord Why haven't you checked into rep rehab yet?MortsAccord Why haven't you checked into rep rehab yet?MortsAccord Why haven't you checked into rep rehab yet?MortsAccord Why haven't you checked into rep rehab yet?
A little didy about fuses.
Before anyone ever installs a fuse, splices a wire or modify anything that has to do with elctricity, they should read this: FUSES
http://motoroilbible.com/mob-2-2-04.pdf
http://www.bcae1.com
Private server Diablo II anyone?
http://www.superhonda.com/forum/f161...server-339391/
MortsAccord is offline
Old 07-22-2008, 11:17 AM   #15 (permalink)
Official SH Vendor
Car: 5th Gen. Honda Accord
Mods: Energy bushings, Tokico Illumina shocks, Eibach sportline springs, Sus. Tech. sway bars, 16" rota rims, Falken Tires, Goodridge brake lines .
TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?
They just mean to put a fuse between a peice of wire so you dont short the fan electricals. If you just tap the power wire of the fan to the battery quickly, you will know if it works.
TOP END Motorsports - Bring your ride to the next level of style and performance ..
AccordRacing.com - Honda Accord style and performance forums - since 2000 ..
Mt. Fuji Motorsports - Reaching for Higher Performance Through the Honda Accord .. *THE ACCORD STORE*
TOP END MS is offline
Thread Too
