Old 05-14-2006, 10:53 PM   #1 (permalink)
Official SH Vendor
Car: 5th Gen. Honda Accord
Mods: Energy bushings, Tokico Illumina shocks, Eibach sportline springs, Sus. Tech. sway bars, 16" rota rims, Falken Tires, Goodridge brake lines .
TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?
How NOT to install a fuel filter ..
I tried to change my fuel filter to an AEM and failed miserably .. I could not get the bottom nut loose .. and then I couldnt get the bracket to line back up with the frame. I found doing a search I need a 'Crows foot' wrench adaptere .. so I got that and an additional 10" extension .. plus the 10" i already had .. so I got 20" extention plus the crows foot and an elbow peice if i need it so I think it should be cake now .. but I used the supplied crush washers when I put the OEM back .. now I cant find any more crush washers .. I wen to Home Depo and AutoZone but they didnt have shitttt. .. whwere can I get them?
TOP END Motorsports - Bring your ride to the next level of style and performance ..
AccordRacing.com - Honda Accord style and performance forums - since 2000 ..
Mt. Fuji Motorsports - Reaching for Higher Performance Through the Honda Accord .. *THE ACCORD STORE*
TOP END MS is offline
Old 05-14-2006, 11:03 PM   #2 (permalink)
Lifeless Ninja
DrivinVtec's Avatar
Car: Honda
DrivinVtec has a Rep problemDrivinVtec has a Rep problemDrivinVtec has a Rep problemDrivinVtec has a Rep problemDrivinVtec has a Rep problemDrivinVtec has a Rep problemDrivinVtec has a Rep problemDrivinVtec has a Rep problemDrivinVtec has a Rep problemDrivinVtec has a Rep problemDrivinVtec has a Rep problem
pepboys,autozone, any car place should have them. try another place like homedepot. i know u went there already. thats crazy they dont have anymore.
Vouch list:
PreludeClone, US_Marine, getbig, BurntRubber87, v8kill r, VTECnLUDE, westcc1827, SpliF3d, cardudelude, Ludatic_024, glazethatj, dread_accord, goldhatch95, jtdesigns, dom yo, H23lude92, Type_SH RaCer, 95integrars, rnstein69, AkronCrxSi,theflipimage, kacivic, chris_s14, 93_delsol
Originally Posted by jtdesigns View Post
Your like the luckiest fool I've ever known.... sand storm= free paint and windows.... now you bust your value keeper and dont bust a hole in your piston just at the time you pull it and rebuild...........
i mean damyn if i was you id go by and get a lotto ticket!!
DrivinVtec is offline
Old 05-14-2006, 11:24 PM   #3 (permalink)
g00dfella is an unknown quantity at this point
yea check autozon or pepboys or discount or whatever...
CLICK HERE FOR FREE MONEY!!!!
g00dfella is offline
Old 05-15-2006, 12:15 AM   #4 (permalink)
Official SH Vendor
Imma try pepBoyz .. they usually always have what I need ..
Old 05-15-2006, 06:45 PM   #5 (permalink)
accordpower99 is infamous around these parts
go to a tire/oilchange shop, sounds wierd, but the garage i use to work at had a shit load of them, we always had to find ways to cover up leaks,
accordpower99 is offline
Old 06-13-2006, 03:01 PM   #6 (permalink)
goon is an unknown quantity at this point
lol im having the same damn problem. Can you give me a link to that crows foot you used. I have a 97 Accord SE. I had to take the Brake Fluid off to get to it but still couldn't get it off....
goon is offline
Old 06-13-2006, 03:04 PM   #7 (permalink)
nvm used googled LOL sorry. Hum I'm going to try it now. Did you say you got the aem fuel filter the one you can screw to top off and just change the filter inside? Hows it working out for you? Im thinking of getting one.
goon is offline
Old 06-14-2006, 01:13 AM   #8 (permalink)
Official SH Vendor
I havent even tried since my last attempt b/c last time i had to put it back and use the new cursh washers .. now if i mess up again I have to order new washers .. I was thinking of getting a Euro R intake manifold and just putting it on while thats off.
Old 06-14-2006, 05:48 PM   #9 (permalink)
I bought the Service manual for my car and stuff and it said to use a flare bolt wrench so I got a set of thoese and the crows with a 20' ext. Ill probably do it tonight and let you know.
goon is offline
Old 06-14-2006, 06:06 PM   #10 (permalink)
Official SH Vendor
Plus I must have bend something b/c I cant get the mounting bolt to get back in ..
Old 06-14-2006, 10:41 PM   #11 (permalink)
LMFAO yea im having the same troubles I took off the top bolt to the fuel filter fine then thought if I took of the mounting braket it would help to get to the under bolt of the fuel filter nope. Now that I have the crows 19mm and 14mm with 10" ext to do it underneath the car the fuel fiter moves because its not held down by the mounting braket. I first had to put the long notch in the slit of the frame that holds the mounting braket in place then hold down the braket with vise-grips and skew down the bolt that tightens down the fuel filter then last to the bolt to frame work fine like that.
goon is offline
