The maint required light is staying on, The oil had been changed alone with the filter, brake fluid is full and everything is top off, Does anyone have any thoughts about what could be going on, I just changed the rear o2 sensor,
everything is running good, No codes are comming up now.
that light has nothing to do with the check engine light
try this
I believe you hold down the reset button for 10-15 seconds while the key is in the ignition but in the OFF position, then after 10-15 seconds you turn your key (finger still on reset button) to the first position for about 5 seconds and then let go of the reset button. See if that works.
I have a new problem with her car now, The little brake light at the bottom of the dash is staying on now, Im thinking i will need to change the pads again, I was wanting to get some info on this before i do anything, I checked the brake res, and toped it off, thinking that may be the problem, Any thoughts about this.
Im thinking it is the brake pads, The brake light stays off until you step on the brake peddle. Then the light comess on. I checked the float in the resevor, and it is not stuck, Im thinking it all comes back to the pads.
Doesn't make sense to me how the pads will cause the light to come on when you depress the brake pedal. Brake fluid is at the max level right? How much life left on your pads?
Im not sure how much is left onthe pads, The wife drives like mario, She don't put on the brakes or let off the gas until she is right at where she needs to stop at. The fluid is full, The parking brake handel is all the way down, I will be pulling the tires off tomorrow and takeing a look.
Related Threads
Honda and Acura Car Forums
4.2M posts
169.9K members
Since 2002
