I have a 1992 accord, problem is the car will run when it wants to hot or cold does not matter. Some days the car will star and others it will just sit their and backfire. Now I have replaced distributor, coil, plugs and wires, I've done a compression test all cylinders are between 190-210, the car seems to be getting plenty fuel, need suggestion please
^^^ also try the paper clip trick, if you have a check engine light on look for your ECU there should be a wire with a geen cap grab it stick a paper clip in both holes of the plug and count how many times the light goes on a and off. every single time its a different code itll take abt 2sec til the light starts to go on and off again. then search what those means=] goodluck!
Related Threads
Honda and Acura Car Forums
4.2M posts
169.9K members
Since 2002
