» Sponsors
» Sponsors
SuperHonda.com is the premier Honda forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 11-09-2007, 07:00 PM   #1 (permalink)
cutterb11 is on a distinguished road
odometer lights
I have a 1999 Honda Accord. My instrument panel lights work but the light to illuminate the odometer is burned out. I need to access the bured out light and replace with a new bulb. I can't find anywhere how to dismantle the dashboard and replace the light. Any help would be greatly appreciated.
Thanks in advance
cutterb11 is offline
Old 11-11-2007, 05:08 PM   #2 (permalink)
Car: 1998 Honda Accord Coupe LX V6
rchspimpin306 will become famous soon enoughrchspimpin306 will become famous soon enough
mines the same way, but i kinda like it that way i cant see the 216xxx every day.....but i think its been talked about on here before...id try a search
98 Accord V6 Coupe - a few bolt on's.
rchspimpin306 is offline
Old 11-11-2007, 05:26 PM   #3 (permalink)
Car: 95 Accord EX 5-spd
PaHonda so um, come here often?PaHonda so um, come here often?PaHonda so um, come here often?PaHonda so um, come here often?PaHonda so um, come here often?PaHonda so um, come here often?PaHonda so um, come here often?PaHonda so um, come here often?PaHonda so um, come here often?PaHonda so um, come here often?PaHonda so um, come here often?
http://hondatech.info/downloads/Auto/Manuals/Accord/
this site has an iso file of the shop manual for 98-02 accords. Download it and use CD burning software like nero or ez cd creator to make a cd of the manual.
95 Accord EX 5-spd
PaHonda is offline
Old 04-26-2009, 06:24 PM   #4 (permalink)
olopc is on a distinguished road
Step by Step Odometer Light Replacement
I just replaced mine on a 2000 Accord. I'll bet it is the sameon your car. 1. remove the top two screws to the black plastic holder around the instrument cluster. 2. pull the black plastic holder straight out toward you - not up, not down - straight back toward the steering wheel. You may want to take off the top of the steering column cover, but not necessary. This will give you something underneath the plastic holder to grab onto. Note that there are two clips on the bottom left and right of the black holder, which cannot be reached from the outside. They simply unplug from the car once you pull straight out. It took a pretty good hard pull. There are also two guides which hold the bottom of the black holder down in the center up against the cluster. 3. After the black cover is off, take out the two top and the two bottom screws which mount the instrument cluster to the car. 4. tilt the top of the cluster forward to you, keeping the bottom in place. Unplug the three wiring harnesses from the instrument cluster's top. There is a small button to push on each to release them from the cluster. 5. Pull out the cluster. If you need more room, you may need to remove the top of the steering column cover. Don't remove the bottom cover, or it will take you a week to get three screws on the bottom lined up again. Twist out the light bulb holder from the bottom back of the cluster. I took the bulb and the holder to the auto parts store and matched up a new one - it is very small. The one I bought was a little longer than the original, but fit and worked fine. It was $2.99 for a package of two. 6. Thank God you did not have to pay the $100 my dealer wanted to do the job!
olopc is offline
