Old 04-02-2002, 06:10 AM   #1 (permalink)
Car: Sec. Sup.
pnc/Rcer is an unknown quantity at this point
tech wrench Problem w/ strut bar install
I just got a Neuspeed strut bar and I can't install the damn thing. The three bolts that your supposed to remove on each side is the problem. The three on the passenger side won't budge. I've tried everyting I know(liquid wrench, socket wrench, Normal wrench, universal wrench gator grip) but they still won't budge. any suggestions would be appreciated.
Thanks in advance.
Forget your mirrors, I'm that white blur in front of you!
pnc/Rcer is offline
Old 04-02-2002, 04:47 PM   #2 (permalink)
Car: 1995 Accord EX
the wing is a splendid one to beholdthe wing is a splendid one to beholdthe wing is a splendid one to beholdthe wing is a splendid one to beholdthe wing is a splendid one to beholdthe wing is a splendid one to beholdthe wing is a splendid one to behold
put some ooomph into it
those bolts were probably torqued down from factory.that plus dirt and grime from the engine is making them stick, try using a large ratchet like1/2 in or putting a pipe onto the ratchet for more leverage.
the wing is offline
Old 04-03-2002, 08:52 AM   #3 (permalink)
GunMetal Member
AznAccord99 is an unknown quantity at this point
yeah. i had a bitch of time removing mine too..
but i got a cheap ass strut so it didn't even fit correctly..
so its kinda sitting on half the bolts and under half the bolts.
its hard toe xplain..
i think i'm gonnna take it off soon..
AznAccord99 is offline
Old 04-03-2002, 09:23 AM   #4 (permalink)
Car: student-UCSB
9accord6 has a little shameless behaviour in the past
try loosen it with some dissolvant liquid or something...i know they have something like that to get things off when they are stuck...do this before you apply more leverage you dont wanna break the whole bolt
96 Accord LX 4cyl. black
with 90k on it
AEM CAI
alarm,
altezzas,
indiglo gauges,
naxos 9005 conversion,
Jensen MP5010K MP3/CD,
Yokohama Parada 215/40-18
Motegi MR7 18x7.5 +45 offset
Greddy Evolution exhaust
Wings West W-Type kit
Eibach Pro-Kit (1.2 drop) springs
9accord6 is offline
Old 04-03-2002, 11:25 AM   #5 (permalink)
nitelyfe is an unknown quantity at this point
WD-40... thats all I have to say.
99 F23A4 EX-L dark emerald coupe
My OLD ride
minor mods, exterior and interior
My 2001 Aegean Blue neck breaker atriot:
nitelyfe is offline
Old 04-03-2002, 05:32 PM   #6 (permalink)
sadiztik-r's Avatar
Car: 1995 Accord Wagon
Mods: HKS Exhaust, H&R Springs, RACTIVE Intake,
sadiztik-r has much to be proud ofsadiztik-r has much to be proud ofsadiztik-r has much to be proud ofsadiztik-r has much to be proud ofsadiztik-r has much to be proud ofsadiztik-r has much to be proud ofsadiztik-r has much to be proud ofsadiztik-r has much to be proud of
to try to help out
soak em in wd-40 over night
then soak em again in the morning
then try to remove them
if this doesnt work try a impact wrench
if not just dose the fucker in WD-40 for uh couple days
then if all else fails get a new car
sadiztik-r is offline
Old 04-03-2002, 05:39 PM   #7 (permalink)
91HondaAccord is an unknown quantity at this point
I always use a Product called PB Blaster , excellent penetrating oil , but everyonce in awhile i come across a bolt that won't budge , I have replaced nearly all of them on my accord. Spray each nut with a good dose of PB blaster , lay a bundled up rag over the nuts and pour a can of coke onto the rag , the acid in the coke will bust loose anything. KInda a sick thought since we drink that shit on a daily basis........ but it works:
91HondaAccord is offline
Old 04-04-2002, 04:01 AM   #8 (permalink)
Car: Sec. Sup.
Thanks for the sugestions guys, this is how its going.
WD-40 didn't work.
Penetrant didn't work.
didn't try PB blaster yet.
Don't have access to an impact wrench
If the PB Blaster and coke thing doesn't work I'll just Pull out the trusty dremell and replace the damn bolt.
Thanks again for the help.
pnc/Rcer is offline
Old 04-04-2002, 04:10 AM   #9 (permalink)
Car: 2002 WRX
Mods: LOTS!!!
Team Zzyzx is an unknown quantity at this point
leverage, get a breaker bar on there, then use a steel pipe thats about 2-3 feet long, that fucker will bust loose then. Well in theory it should.
Team Zzyzx is offline
Old 04-05-2002, 10:36 PM   #10 (permalink)
Car: 98 Accord Sedan
Mods: Neuspeed strut tower bar, Suspension Techniques front and rear sway bars, Tokico gas shocks, H&R OEM Springs...Oh yeah, and a genuine Honda leather steering wheel cover
98Accsedan is an unknown quantity at this point
I have the same car and the same strut bar. Try jacking the front of the car off the ground to relieve the pressure against the bolts.
98Accsedan is offline
Old 04-05-2002, 11:10 PM   #11 (permalink)
I honestly try to avoid using a long leverage breaker bar on anything smaller than a 1\2 inch \16mm , especially a bolt\nut that hasn't been removed in a long time , I've broken many bolts like that. if worse comes to worse , go to sears and get a Mapp gas torch and heat up ONLY THE NUT . have your socket ad ratchet ready and also a cup of water , when the bolt gets hot , dump some cold water on the nut , the instant contraction from going hot to cold can sometimes break the rust , just get the ratchet on quick and turn it
Old 04-07-2002, 12:31 AM   #12 (permalink)
Car: 2000 Accord Lx 4dr
Mods: AEM Short Ram Intake, H&R 1.75" Sport Springs, Tokico Blue Struts, Strut Tower Bar, Matrix 9.3mm ignition wires, 17" RH C2000 w/ Nitto 450 215/45 R17, Ingalls Rear Cam, Clear/Black Headlight Housing, Polarg Super White Headlights, Xenon
shdwninja is an unknown quantity at this point
tech wrench Metrench!
I used the infamous Metrench to install mines and it was installed in not time at all. Its true you need some power to budge them, but its real easy after that. Remember Righty Tighty, Lefty Loosey!!!
2000 Accord 4DR LX 5spd
Matrix 9.3 mm Ignition Wires
Tokico Blue Gas Struts
Ingalls rear camber kit
19" RH C2 Evo w/ Nitto 555 225/35 R19
OEM conversion Clear/Black Headlight Housing w/ PIAA Xtreme White Plus lights
Xenon Front lip
shdwninja is offline
Old 04-07-2002, 12:34 AM   #13 (permalink)
PS...
Also if you have the stock strut bars (the black "L" lloking things on the strut tower) Then loosen them on the strut and the other end is found under the plastic by the base of the windshield wipers....there should be a cover. Loosen the nuts there too.
Xenon Front lip
Old 04-07-2002, 10:02 AM   #14 (permalink)
Car: Comp tech
souljad9 is an unknown quantity at this point
2 words for you : "impact gun"
I love having air tools
souljad9 is offline
