Old 03-18-2005, 11:44 AM   #1 (permalink)
Car: '97 Accord EX & '98 F150 4x4 ext cab Lariat
spray004 is a rep whorespray004 is a rep whorespray004 is a rep whorespray004 is a rep whorespray004 is a rep whorespray004 is a rep whorespray004 is a rep whorespray004 is a rep whorespray004 is a rep whorespray004 is a rep whorespray004 is a rep whore
Rear disc question...
On a '97 Accord w/ rear discs. What is the size of the two screws that hold on the disc? Mine are stripped so I'm going to have to drill them out and tap them. I gotta do all of this because of a stinking rear wheel bearing .
spray004 is offline
Old 03-18-2005, 01:18 PM   #2 (permalink)
syc
syc has a spectacular aura aboutsyc has a spectacular aura about
you shouldn't need to tap it. i used a big enough drill (the size of the screw itself or slightly bigger) where it will drill out just the head of the screw.. once the head falls off, the disc is free and you can remove the rest of the screw once the disc is off.
99 Accord EX (DIY's) | 97 Civic DX hatch (DIY's) | 97 BMW M3 (DIY's) | 01 Honda s2000 | 06 Evo IX
2005 CalClub FSP Champion
2006 OKSCCA BSP Champion
2006 OKSCCA Overall Points Champion
Team Motocrew
syc is offline
Old 03-18-2005, 01:22 PM   #3 (permalink)
I dunno, it seems pretty rusted and locked on tight. If anyone knows the right size (save me trips to the store). I could drill just the head off, screw on a nut, weld it in place and use a wrench to remove it then.
spray004 is offline
Old 03-18-2005, 07:00 PM   #4 (permalink)
JOEL2112 You need a lifeJOEL2112 You need a lifeJOEL2112 You need a lifeJOEL2112 You need a lifeJOEL2112 You need a lifeJOEL2112 You need a lifeJOEL2112 You need a lifeJOEL2112 You need a lifeJOEL2112 You need a lifeJOEL2112 You need a lifeJOEL2112 You need a life
Don't waste your time. i JUST did mine 2 weeks ago. the screw is only about 1/4 of an inch long and will fall out as soon as the head is drilled. if the threads on the hub are not damaged by you drilling them, you can get those screws at the auto parts store in the "help!" section of products. they are actually labeled "honda rotor screws" i bought some but one of the hubs' threads were stripped when i drilled it. if you think about it, you do not need the screws anyway...my wife's car doesn't have any at all.... they just put them on to hold the rotor during assembly at the plant.... remember when you try to take most rotors off , you have to tap it a few times--to loosen it, even without those screws........
95 EX Coupe
Neuspeed drop
Altezza tails & clears
Polarg Bulbs
Real Philips HID (now it is)
AEM short ram intake
DIY - JDM headlights
Indiglo Guages
Llumar tint
JOEL2112 is offline
Old 03-25-2005, 10:39 AM   #5 (permalink)
Finally got the rear brakes and discs replaced, BUT now when I come to a stop, I hear a grinding/scrubbing sound. It only does this when I apply the brakes so therefore nothing is dragging on the rotor. I used plenty of anti squeel on the pads so I know its not that. I'm thinking that either the pads are defective or the pads and just making noise because of the cross hatching on the rotors hasn't worn off. What do you think?
spray004 is offline
Old 03-28-2005, 05:29 PM   #6 (permalink)
Official SH Vendor
Car: 5th Gen. Honda Accord
Mods: Energy bushings, Tokico Illumina shocks, Eibach sportline springs, Sus. Tech. sway bars, 16" rota rims, Falken Tires, Goodridge brake lines .
TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?TOP END MS What did you do to deserve all this rep?
yup. this happened to a buddy of mine. The screws got stripped and wouldnt come out. use a small drill bit (thinner than the screw), and drill out the head a little bit, then keep trying with the screw driver and it should come right out with out much effort. IF your rotors didnt come with new screws, goto www.hondaautomotiveparts.com and get them. I would wouldnt recommend drilling them out to a bigger size and tapping bigger screws b/c its TOTALLY not needed.
TOP END Motorsports - Bring your ride to the next level of style and performance ..
AccordRacing.com - Honda Accord style and performance forums - since 2000 ..
Mt. Fuji Motorsports - Reaching for Higher Performance Through the Honda Accord .. *THE ACCORD STORE*
TOP END MS is offline
Old 03-28-2005, 06:56 PM   #7 (permalink)
illusion's Avatar
Car: 05 WRX, 07 335i, 07 1098S, 09 Corolla
Mods: WRX Lots, bimmer some, bike a few, and commuter box none
illusion needs rep therapyillusion needs rep therapyillusion needs rep therapyillusion needs rep therapyillusion needs rep therapyillusion needs rep therapyillusion needs rep therapyillusion needs rep therapyillusion needs rep therapyillusion needs rep therapyillusion needs rep therapy
I always use and imact driver(I think that's the right name, you whack it with a hammer and it turns like a screw driver) to get those nasty screws out, but if they are stripped I'd just drill or dremel off the head so you can slide the rotor off, then put some penetrating oil on it for a while and grab it with vice grips.
some day I'll grow up......maybe.
Slow 09 Corolla (great gas mileage)
Quick 07 335i (Vishnu Stg1)
Quicker 07 Ducati 1098S (Two Brothers dual slip ons)
Even quicker 05 WRX (Mean Tranny + Big Motor + Big Turbo + Meth = YIKES)
WTH??? The older I get the slower my cars are getting
Some Previous Rides: 91 3G Lude Built H23 with T3/T04e, 88 Guards Red 930 Turbo Slantnose(AKA the ticket magnet), 53 Bel Air 502 with an 8-71 and juice. Quite a few others, but not enough room. Oh an 01 V6 Accord too, probably how I got that funny title.
illusion is offline
Old 03-28-2005, 07:57 PM   #8 (permalink)
Car: 01 accord sedan
Mojeans69 is an unknown quantity at this point
I changed my rotors 2 weeks ago and only one of my screws were rusted, the impact driver didn't do anything. I had to drill the head and the rotor came right off, and I was able to take the "body" of the screw out with my hands. :clap
Mojeans69 is offline
