Replacing an alternator belt on 94 Accord - Honda Forum : Honda and Acura Car Forums
Wheel & Tire Center
Old 08-28-2009, 09:57 AM   #1 (permalink)
Car: 1994 Honda Accord LX
Mods: The Car is stock for now with minor mods not worth listing. WILL CHANGE THEE ENTIRE VEHICLE.
Greatness What did you do to deserve all this rep?Greatness What did you do to deserve all this rep?Greatness What did you do to deserve all this rep?Greatness What did you do to deserve all this rep?Greatness What did you do to deserve all this rep?Greatness What did you do to deserve all this rep?Greatness What did you do to deserve all this rep?Greatness What did you do to deserve all this rep?Greatness What did you do to deserve all this rep?Greatness What did you do to deserve all this rep?Greatness What did you do to deserve all this rep?
Im having trouble replacing the alternator belt. Im not sure which bolts Im suppose to remove. Which bolts releases the tension in the alternator belt on a 94 accord??
Greatness is offline
Old 08-28-2009, 10:50 AM   #2 (permalink)
accordvtec94's Avatar
Car: 94 Accord EX
accordvtec94 In the stratusphereaccordvtec94 In the stratusphereaccordvtec94 In the stratusphereaccordvtec94 In the stratusphereaccordvtec94 In the stratusphereaccordvtec94 In the stratusphereaccordvtec94 In the stratusphereaccordvtec94 In the stratusphereaccordvtec94 In the stratusphereaccordvtec94 In the stratusphereaccordvtec94 In the stratusphere
You don't have to remove any of the bolts at all. There are only 2 pivot bolts on the alternator which have to be loosened, one on top and the other on the bottom of the unit. If you're standing in the very front of the car looking down at the alternator, tucked underneath it, there is a long 10mm bolt which you have to "loosen" but AFTER the 2 large pivot bolts in the front of the alternator are already loose. That small 10mm bolt is what will move the alternator in one direction or another. The easiest way to get to that adjuster bolt is to use quarter-inch ratchets, sockets, and extensions.
accordvtec94 is offline
Old 08-28-2009, 01:09 PM   #3 (permalink)
mattliston's Avatar
if it doesnt move by hand when its loosened, get a hammer and lightly tap it towards the motor, then simply pop the belt off.
you guys are lucky, you dont have to do shit to replace your alt belt. D series and B series, you have to loosen the timing belt mount and move the motor to get a ratchet in place, unless you have an angled gear wrench
All about the single cam
Originally Posted by My Caramel Chocolate Lover View Post
mattliston is offline
Old 08-28-2009, 06:33 PM   #4 (permalink)
I appreciate the help guys
Old 08-29-2009, 08:16 AM   #5 (permalink)
Car: 94 Camaro z28
user12 you're still here?user12 you're still here?user12 you're still here?user12 you're still here?user12 you're still here?user12 you're still here?user12 you're still here?user12 you're still here?user12 you're still here?user12 you're still here?user12 you're still here?
ugh! why can't honda figure out what a belt tensioner is.
user12 is offline
Old 08-29-2009, 08:50 AM   #6 (permalink)
mattliston's Avatar
because they seem to make shitty ones, like the AC tensioners that fail every five minutes
