Squealing noise in a 1994 Accord LX - Honda Forum : Honda and Acura Car Forums
Wheel & Tire Center
Old 08-26-2009, 09:33 AM   #1 (permalink)
Car: 1994 Honda Accord LX
Mods: The Car is stock for now with minor mods not worth listing. WILL CHANGE THEE ENTIRE VEHICLE.
Greatness What did you do to deserve all this rep?Greatness What did you do to deserve all this rep?Greatness What did you do to deserve all this rep?Greatness What did you do to deserve all this rep?Greatness What did you do to deserve all this rep?Greatness What did you do to deserve all this rep?Greatness What did you do to deserve all this rep?Greatness What did you do to deserve all this rep?Greatness What did you do to deserve all this rep?Greatness What did you do to deserve all this rep?Greatness What did you do to deserve all this rep?
There's a loud squealing noise coming from the under drive pulleys in my car. The sound seems to originate from the pulley belts. At first I thought it was the power steering belt that was making the noise. So I put a new power steering belt and the car is still making the noise loud as ever. I did have an oil spill in my car because somebody stole my oil cap and I drove off without it. The next time I opened my hood I saw a complete mess with oil all over the pulleys. I recently cleaned the pulleys 3 times thoroughly with engine degrease and spraying it down with water. The noise seems to disappear when I spray the pulleys with water while the car is running but comes right back as soon as I stop spraying it with water.
When I drive my car it squeals when I have it in gear. The higher the rpms the louder the noise. If I put it in neutral and rev the car the noise goes away for a little while. I dont have any power steering fluid because it all leaked out of the car a months ago but this noise just recently started and it seems to be getting worse.
Help would be appreciated.
Greatness is offline
Old 08-26-2009, 09:34 AM   #2 (permalink)
hotsauce_gm's Avatar
Car: 2015 Jeep Wrangler Unlimited
Mods: Altitude
hotsauce_gm Bow down before me!hotsauce_gm Bow down before me!hotsauce_gm Bow down before me!hotsauce_gm Bow down before me!hotsauce_gm Bow down before me!hotsauce_gm Bow down before me!hotsauce_gm Bow down before me!hotsauce_gm Bow down before me!hotsauce_gm Bow down before me!hotsauce_gm Bow down before me!hotsauce_gm Bow down before me!
timing belt or bad bearings in the alternator or power steering
hotsauce_gm is offline
Old 08-26-2009, 09:40 AM   #3 (permalink)
mattliston's Avatar
are you kidding me? you sprayed water on a running motor :facepalm I know you were trying to figure it out, but thats not a good idea man
do you have AC? check the tensioner
running without PS fluid? you fucked your PS pump, most likely cause of the sound.
hotsauce, why say timing belt? neutral revs=less load=less noise? i dunno man, i never heard a timing belt make noise unless its damaged/flapping around while teh valves are being bent lol
All about the single cam
Originally Posted by My Caramel Chocolate Lover View Post
mattliston is offline
Old 08-26-2009, 10:15 AM   #4 (permalink)
Car: 1991 Accord
Mods: JDM F22B DOHC/Delta 260 regrind/Wiseco 85.5mm 11:1 pistons/Megan 4-2-1 header/AEM CAI/Apexi WS2 catback exhaust//Bisimoto 8.9lb flywheel/JDM M2A4 tranny
91Accord-lx In the rep troposphere91Accord-lx In the rep troposphere91Accord-lx In the rep troposphere91Accord-lx In the rep troposphere91Accord-lx In the rep troposphere91Accord-lx In the rep troposphere91Accord-lx In the rep troposphere91Accord-lx In the rep troposphere91Accord-lx In the rep troposphere91Accord-lx In the rep troposphere91Accord-lx In the rep troposphere
As stated, it might be your PS pump due to you running it with no fluid. I would just remove the PS pump all together and see if that lessens/gets rid of the noise.
While you are checking the tension on the AC, I would also do the same with the Alternator as well.
9.8:1 > 11:1
91Accord-lx is offline
Old 08-26-2009, 10:21 AM   #5 (permalink)
mattliston's Avatar
dont remove the PS pump, thats a foolish suggestion. maybe you meant the PS belt?
just remove the AC and PS belts, and check the alternator belt like 91accord suggested
Old 08-26-2009, 01:22 PM   #6 (permalink)
I'm going to remove the power steering system. I was going to replace it with a manual rack and pinion system anyways. Someone also suggested it may be loose pulleys.
Old 08-26-2009, 01:41 PM   #7 (permalink)
mattliston's Avatar
why would you remove the powersteering system? thats stupid, all that effort for 1.2 horsepower and 0.000001 mpg better
:facepalm
Old 08-26-2009, 02:50 PM   #8 (permalink)
:facepalm
Not for the horsepower or gas mileage
I hate power steering. I like the feel of the road and control I have without. It feels like Im steering the car not the fluid.
Old 08-26-2009, 03:30 PM   #9 (permalink)
mattliston's Avatar
honda powersteering isnt as great as people think, you feel the road plenty with it
maybe if the system was similar to a cadillac, then I would agree to go for it, but hell, even the NSX had power steering, and that car was designed for handling
Old 08-27-2009, 02:43 PM   #10 (permalink)
I found out it was the alternating belt causing the noise. So im going to go ahead and change the belt.
Old 08-27-2009, 02:48 PM   #11 (permalink)
mattliston's Avatar
good deal
Old 08-27-2009, 04:28 PM   #12 (permalink)
good deal
thx guys I appreciate the help
Old 08-30-2009, 04:32 PM   #13 (permalink)
Car: 1991 Accord
Sorry, I did mean the PS belt NOT the pump. lol
Greatness- I would just leave it hooked up and run it. About the only thing losing the PS on it would do is make it a little harder to turn and not fun to parallel park. When I removed mine, I felt NO difference in "feeling the road". I actually put it back on a week later.
9.8:1 > 11:1
Old 08-30-2009, 05:02 PM   #14 (permalink)
mattliston's Avatar
yeah, that's what I was getting at. its basically a parking assist stealing nearly zero power
