TPS Broken?
I'm getting code 7, tps(throttle position sensor). I checked, and I'm getting 5 volts to the tps, and I checked all the wires and connections in the circuit and they look good. So then I check the voltage with the key on, and I'm getting .001v(closed) - 3.0v(wide open), so the voltages are low.
My question is, will I get a code if it's not adjusted correctly, or if the initial voltage is too low? Or will it only give the code if the tps is bad? And am I getting those voltages because it isn't adjusted correctly, or has it gone bad? Thanks.
