Go Back   Honda Forum / Acura Forum - SuperHonda.com > Honda Lifestyle & Entertainment > Off-Topic Lounge > R/C & Model
Old 05-08-2005, 07:25 PM   #1 (permalink)
Car: 2001 Accord V6
Mods: none
canadian1986 has much to be proud ofcanadian1986 has much to be proud ofcanadian1986 has much to be proud ofcanadian1986 has much to be proud ofcanadian1986 has much to be proud ofcanadian1986 has much to be proud ofcanadian1986 has much to be proud ofcanadian1986 has much to be proud ofcanadian1986 has much to be proud ofcanadian1986 has much to be proud of
cold weather... no?
im guessing these bad boys dont run so good in cold weather? i was out trying to tune mine tonight, first it was a bitch to start, and i have to richen up the mixture A LOT, and it seemed sluggish. can all this be attributed to the cold weather im running it in?
also i was diddling with the idle and low speed mixture screws and accidently loosened both of them too much.. basically i just turned opened the throttle until i was able to screw the idle back in and i just pushed the low speed screw in until those two things inside the carb met and i tightened it.. im assuming i did this right? because the car does run now lol
im still such a noob
canadian1986 is offline
Old 05-08-2005, 09:00 PM   #2 (permalink)
VTECsqznN2O's Avatar
Car: 1990 SI Hatch
your instruction manual should have the instructions on where to set the screws as a basic tune..then you would tune it yourself from there....as far as cold weather...i think it does make them more finicky...but I live in so cal and haven't noticed much of a difference. so cal weather > all
Kevin
Dynamic Mayhem Motorsports
VTECsqznN2O is offline
Old 05-09-2005, 08:14 AM   #3 (permalink)
krazykloudz needs rep therapykrazykloudz needs rep therapykrazykloudz needs rep therapykrazykloudz needs rep therapykrazykloudz needs rep therapykrazykloudz needs rep therapykrazykloudz needs rep therapykrazykloudz needs rep therapykrazykloudz needs rep therapykrazykloudz needs rep therapykrazykloudz needs rep therapy
mine ran in the winter, but it was a little harder to start and to tune, but the cold air seemed to make it run like a raped ape. that's when i wish my carb had the fine tune adjusters like my os airplane engines.
krazykloudz is offline
Old 05-09-2005, 09:12 AM   #4 (permalink)
mike_sho's Avatar
Car: 93 Honda Prelude VTEC
Cold motors are harder to start...this changes a lot of things for one in the air fuel ratio. As well the motor needs a little heat so its easier to start. The motor runs off heat through the glow-plug...so when there is less its harder for it to run.
Simple fix , get a heat gun or hair dryer and warm the heat-sink up inside then step outside quickly and start the sucker up.
mike_sho is offline
Old 05-09-2005, 11:20 AM   #5 (permalink)
Originally Posted by mike_sho
Cold motors are harder to start...this changes a lot of things for one in the air fuel ratio. As well the motor needs a little heat so its easier to start. The motor runs off heat through the glow-plus...so when there is less its harder for it to run.
they need engineblock heaters like for diesels, lmao
