Mods: Currently Stripped completely....Fuckin Crooks.
all motor z6/y8???
has anyone ever heard of a FULLY BUILT z6/y8 ?
i wanna know what they can do with crazy cams and high c/r pistons and what not . i want to know what these things can do all motor PROPERLY built and tuned
ill tell you. not much.
im sure its been done and the results are decent, never seen it done on here. perhaps google, or the search function may help you in your quest?
'90 crx Si
damn!! i at least want to break 14's maybe mid or high 13's i would be satisfied.
id like to go all motor sohc first before i go boost. with boost my plans are to hit low 13's high 12's
Years...years ago...there was a kid on here with an all motor D16. Believe the block was stock but he was running a pretty crazy cam (at the time), upgraded injectors, fuel pump, performance intake manifold, larger throttle body, a crazy header, exhaust, extremely gutted car. He was running low or mid 14's at the time. Yes, yes...slow, but at the time, there weren't many street cars with B-series that were much faster then 14's. Hope that helps you keep things in perspective.
__________________ Zero - 00 VSM EX Coupe
Password CF Intake
Carsound CAT
Function Form Coilovers
ST Sways front and rear
99-00 Si Rims Epyon - 96 VSM DX Hatch
AEM Intake
BBR D16Y8 Head and tranny
DC Sports 4-1 Header
Rear disc conversion
D2 Coilovers Hella 3rd Gear VTEC y0!
Password CF Intake
Carsound CAT
AEM Intake
thanx for the encouragement dude i will do it actually my set up will be
12.5:1 pistons
eagle rods
balanced crank
clevite 77 bearings
skunk2 intake manifold
act street lite flywheel
act 6 puck clutch with pressure plate
y8 ex tranny
any bored b series throttle body
dc headers
chipped p28 ecu
bullfrog head
arp head bolts
arp rod bolts
high compression head gasket (thin layer)
to tell you the truth i know for that bull frog almost guarantees 55whp on the head itself so with everything else i dont know what im looking at but if all goes acordingly and im happy with the power output then ill keep it n/a
if not then i got turbo heh
